Community Member
Call Disconnect
Dear All
We have sip line DiD/DoD from PSTN (Telecom Comp.) ,
Call manger V 7.1 , the PSTN using huawei with codec G7.11 Aluw
most of the range working fine , but there are some number wich is analog end point local number, when i call them after they pick up the call , the call immediately disconnects ,
In debug , Previous Disconnect Cause=0, Disconnect Cause=1
ccCallDisconnect:
   Cause Value=1, Call Entry(Disconnect Cause=1)
then
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
then
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
then
Cause Value=41, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Any one have idea can help me
Thanks a lot
Best regards
then 16
then 41
Any one have idea about it.
Everyone's tags (2)
1 REPLY
Hello,Please refer this
Please refer this document for disconnect cause codes & its description:
http://www.cisco.com/c/en/us/td/docs/ios/voice/monitor/configuration/guide/12_4/vt_12_4_book/vt_ccodes_debug.html#wp1007443
it would be good if you could post your gateway configuration with following debugs for a test call.
- debug ccsip message
- debug voice ccapi inout
please include calling/called party numbers
//Suresh
Please rate all the useful posts
//Suresh Please rate all the useful posts.
156
