Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Call Disconnected by no reason
Hi Everyone
I have in my company a CUCM 8.6, when i´m making a local Call with this pattern (0XXXXXXX) the call is established without problems but at any time the communication falls and appears this message in the audio "Your call cannot be completed in this dial", it´s like automatically calls again during the call but i cannot find any issue in the configuration.
I hope someone can help me with this issue.
Start by looking at CUCM
Start by looking at CUCM traces and debugs from the calls, no way to tell what's going on without you first reviewing that.
java
if this helps, please rate
www.cisco.com/go/pdi
Ok.. I´ll make some trace and
Ok.. I´ll make some trace and debugs.
Is that Route Pattern
Is that Route Pattern associated with Route List or directly with End Device? If it is Route List, does it have MGCP gateway? Do you get any Routelist Exhausted alert in RTMT when the issue occurs?
//Suresh Please rate all the useful posts.
Hi, is directly with a Device
Hi, is directly with a Device. In the RTMT i have no alerts. Could this maybe an issue in the voice port configuration?
then we need to collect the
then we need to collect the trace & debugs to see what is happening for the faulty call, please capture the logs for a working call too, so we can compare and check what is wrong. include the calling number, called number and time of working & nonworking calls too.
This is the Call log of the
This is the Call log of the non working call taking with the RTMT collect file:
14:08:39.576|CC|RELEASE|20853838|20853839|16
2014/05/14 14:08:50.625|CC|SETUP|20853860|20853861|8767|06358640|06358640
2014/05/14 14:09:30.277|CC|RELEASE|20853860|20853861
In blue mi extension number, in yellow phone destination.
Then the user called again and works fine:
2014/05/14 14:10:54.529|CC|SETUP|20853865|20853866|8767|06358640|06358640
2014/05/14 14:11:21.896|CC|RELEASE|20853865|20853866|16
2014/05/14 14:12:31.830|CC|RELEASE|20853863|20853864|
In the error Call i add the
In the error Call i add the code:
2014/05/14 14:09:30.277|CC|RELEASE|20853860|20853861|28
Hello Carlos, The cause code
Hello Carlos,
The cause code 28 is for "Invalid number format (address incomplete)". We need to collect the detailed CCM traces thru RTMT & debug isdn q931 & debug voice ccapi inout from gateway for the nonworking call.
Hi. Here i attached the debug
Hi. Here i attached the debug of the failed call, i only made debug voice ccapi inout because the isdn is not permit in my router.
I hope that we can work with this log.
Thanks.
The destination number is: 4269999, with this you can find the event.
Hello Carlos, it is good to
Hello Carlos,
it is good to collect these debug output in .txt file for ease of analysis.
I see the call is made to Called Number=04269999 (8 digits) and the first calling number is 8767(4 digits).
It matched the Incoming Dial-peer=2003 and Outgoing Dial-peer=3,
then the calling number is translated to 7427090 (7 digits).
However it seems the call was connected (may be to an IVR) and you entered the DTMF digits 5538.
After you entered those digits, the call stayed up for about 2 mins and disconnected with cause code 28 from provider side.
- If this happening for the calls only to IVR or to all calls?
- can you please crosscheck if the 7 digit calling number sent to provider (7427090) is correct and valid format?
- if that is correct number format, I suggest you to check with your provider as it is them who disconnecting the call.
//Suresh
Please rate all the helpful posts
Hi.Yes, this only happens
Hi.
Yes, this only happens with IVR calls, the format 7427090 is the correct format (thats our principal line).
To summary you suggest to make the verification with provider the cause of this issue?
It could be neccesary to modify  or add dtmf configuration on my dial peer?
- is the problem only with
- is the problem only with that particular IVR?
- have you tried calling some other IVR system (like banking callcentres)? and how does it work?
- if calls to any IVR is failing, then we need to check how the dtmf is configured on the outbound dial-peers?
- what is the gateway type (h323, sip, mgcp)? what is the connection to provider(T1/E1 PRI, IP-IP CUBE)?
- could you post the gateway configuration?
This don´t happens with all
This don´t happens with all ivr, but i can´t find a relation bettwen them.
My Dial-peer Doesn´t have dtmf configuration:
dial-peer voice 3 pots
 trunkgroup Lines-MTKBOG
 description LLAMADAS LOCALES
 translation-profile outgoing PSTN-OUT
 destination-pattern 0[2-9]......$
 forward-digits 7
This is the voice ports configuration, of my trunk group:
voice-port 0/3/0
 trunk-group Lines-MTKBOG
 supervisory disconnect dualtone mid-call
 supervisory custom-cptone CO
 supervisory dualtone-detect-params 20
 no battery-reversal
 timeouts initial 1
 timeouts call-disconnect 1
 timeouts ringing 5
 timeouts wait-release 1
 connection plar opx 3101
 description LINE-7427090(REVISADO)
 caller-id enable
voice-port 0/3/1
 no battery-reversal
 timeouts initial 1
 timeouts ringing 5
 description LINEA-7433170(REVISADO)
 caller-id enable
voice-port 0/3/2
 no battery-reversal
 cptone CN
 timeouts initial 1
 timeouts ringing 5
 timing hookflash-out 50
 description LINEA-7433171(REVISADO)
 caller-id enable
voice-port 0/3/3
 cptone GH
 timeouts initial 1
 timeouts interdigit 3
 timeouts ringing 5
 description LINEA-7433172(REVISADO)
Thanks for your help.
Hello Carlos,OK, you have the
Hello Carlos,
OK, you have the analog pots connection to provider. I don't think the issue is with your configuration.
If it is not happening for all IVR and if it is specific only to this IVR, then it is something wrong with other side IVR system issue.
by the way, if you call the same number 04269999  from your mobile, how does it work?
I suggest you to talk to provider on this issue as they may help you further to check their side DTMF settings.
//Suresh
Please rate all the helpful answers
Ok. I will check with the
Ok. I will check with the provider the DTMF settings, thanks for all your help.
Have a good day.
117
