Call Display Issue on CCM 7
On in-comming Calls  it's cutting the 1 letter of the Call Display Ext Dave Smith show as ave Smith
, I check the call manager and  Router and i am unable to find the issue. did anyone has the same issue? or is their a bug fix for it ?
Thank you for your Help
1 REPLY
Red
Re: Call Display Issue on CCM 7
Usually, this is caused by mismatched switch type between telco and customer (e.g. telco is DMS-100, customer configured PRI NI2).
In CCM trace, you'll see something like:
08/31/2009 12:07:42.009 CCM|In  Message -- PriSetupMsg -- Protocol= PriNi2Protocol
Check your CUCM and see if CUCM set to the same switch type. (device > trunk).
Hope this helps!
Michael
http://htluo.blogspot.com
144
