Call doesn't terminate properly to CUE when called between CME to CME
Hello Experts,
I am having problem terminationg the call on CUE (version 8.0)  when call is made between one CME to another CME. Call is forwarded to the CUE but no audio, user sees that the call is connected on the CUE pilot number but no audio. I have attached the  debugs of ccsip messages and voice ccapi inout and the config of the dial-peer and voice service voip from troubled site CME (version 9.1);
dial-peer voice 100 voip
description XXXXXX
destination-pattern ^71..
session target ipv4:XXX.XXX.XXX.XXX ( Destination CME address)
dtmf-relay h245-alphanumeric h245-signal
codec g711ulaw
no vad
dial-peer voice 8100 voip
description CUE
destination-pattern 8100
session protocol sipv2
session target ipv4:10.10.YYY.ZZZ
dtmf-relay sip-notify
codec g711ulaw
no vad
voice service voip
ip address trusted list
  ipv4 0.0.0.0 0.0.0.0
no ip address trusted authenticate
no notify redirect ip2ip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.2
no supplementary-service h450.3
no supplementary-service h450.7
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
Any idea ?
Thanks!
1 REPLY
I checked the logs.. CME sent re-invite to CUE with a=recvonly which is causing audio issue.. however logs are insuffient to tell why CME sent this reinvite...
INVITE sip:5100@10.10.156.20:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.10.156.1:5060;branch=z9hG4bK7BF255C
To: <5100>;tag=dsdff5fb70
Date: Thu, 05 Sep 2013 20:57:07 GMT
Call-ID: 8F4554B7-15A411E3-86B3FE17-540888BA@10.10.156.1
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 2403645583-0363074019-2259615255-1409845434
User-Agent: Cisco-SIPGateway/IOS-15.2.4.M3
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 102 INVITE
Max-Forwards: 70
Timestamp: 1378414627
Contact: <7129>
Call-Info: <10.10.156.1:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Diversion: <7313>;privacy=off;reason=no-answer;counter=1;screen=no
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Length: 199
v=0
o=CiscoSystemsSIP-GW-UserAgent 1452 374 IN IP4 10.10.156.1
s=SIP Call
c=IN IP4 10.10.156.1
t=0 0
m=audio 20114 RTP/AVP 0
a=recvonly
Can you please share some more details from both CME:
1. show run
2. debug ccsip all
3. debug cch323 h225
4. debug cch323 h245
5. debug h225 asn1
6. debug h245 ans1
7. debug voice ccapi inout
Cheers !!
Piyush
169
