Call Dropping after 30 minutes SIP/CME
Hey,
I have seen this issue in CUCM but not CME where the call drops after a period.
Its a sip call and not sure what could be wrong, can someone please help me
Please rate the post
Shibly Ibrahim
Please rate the post Shibly Ibrahim
Everyone's tags (2)
1 ACCEPTED SOLUTION
Hello, It seems the CME is disconnecting the call after the default value of Min-SE timer (30 mins) expires.
So, you can try increasing the timer beyond 30 mins (1800 sec) under voice service voip.
Router(config)# voice service voip
Router(conf-voi-serv)# sip
Router(conf-serv-sip)# min-se  <90-86400>  Min value of Session Expires Header (in seconds)
//Suresh Please rate all the useful posts.
Hi Mohamed,
Few more inputs required for further analysis.
Please share the topology and make one test call to get the debug ccsip all and share it.
Nishant Savalia
Regards, Nishant Savalia
Main thing to get to know is who is releasing the cal and what clear code (cause code) you are getting while call is being released?
Nishant Savalia
Hey Nishant,
Please find log below. Call to .
The call disconnected on my mobile but the not the IP phone. The IP phone shows as if the call is still alive but actually its dead.
Shibly Ibrahim
Re: Call Dropping after 30 minutes SIP/CME
This is the log
Shibly Ibrahim
Can you tell which IP address is of which side?
192.168.42.160
88.215.61.195
Also share Calling number & called number?
Nishant Savalia
Hey,
Thanks for your quick response.
192.168.42.160 is the CME address
88.215.61.195 is the SIP Providers address
Shibly Ibrahim
Please share the calling number & called number too because this log contains lot of other number traces.
Also please share your topology i.e do you have sip trunk from CUCM to CME (gateway)?
IP address of CUCM?
Nishant Savalia
Hey,
Calling number : 300   or also shown as ending 33331
Called number: ending 3361
Shibly Ibrahim
Thank you Suresh Subramanian
Thank you Suresh Subramanian for sharing this post.  This also helped me resolve the issues I had recently. Scotland SIP Carrier via the client ISP service.
4337
