Call dropping for My Personal Recording - Cisco unity connection
Hi All,
The call is dropping if i choose My Personal Recording in Callers Hear field but if i select
Note :  The greeting which we try to palying is not record through unity connection, we recorded that file using ordinary desktop and i converted that file from .wma format to .wav format. Unity connection is playing the greeting if i play manually, but not via the call. Please help.
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Hi Murali,
Are you using the Media Master in CUC to upload the custom file?
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/7x/user/guide/assistant/7xcucugasst020.html
The format should be;
CCITT u-Law, 8 kHz, 8 bit mono for the .wave file
Cheers!
Rob
Hi Murali,
Cheers!
Rob
Hi Rob,
Thanks for your reply its very helpful. I just resolved this by sending the call from unity connection to the user to phone to record the greetings.
-murali
375
