07-01-2013 11:14 AM - edited 03-16-2019 06:09 PM
Which trace help me to figure out the CUCM intermitted transfer call dropping issue. Please advice.
Murali.P
Solved! Go to Solution.
07-01-2013 12:30 PM
You can use awesome tool TranslatorX which can be downloaded for free from here:
HTH, please rate all useful posts!
Chris
07-01-2013 11:24 AM
Depending on what version of CUCM you are running, if CUCM 8.6 or below the most useful one will be CCM SDI trace, starting with 9.0 there is no SDI and simply pull the CallManager trace.
HTH,
Chris
07-01-2013 12:27 PM
Using CUCM version 7.1.5. The only way to read the SDI trace is VLT logs?, Please let me know is there is any other way. Thanks
-Murali
07-01-2013 12:30 PM
Chris
