Call dropping issue
Hello All,
Which trace help me to figure out the CUCM intermitted transfer call dropping issue. Please advice.
Murali.P
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Call dropping issue
You can use awesome tool TranslatorX which can be downloaded for free from here:
http://translatorx.cisco.com
HTH, please rate all useful posts!
Chris
Call dropping issue
Depending on what version of CUCM you are running, if CUCM 8.6 or below the most useful one will be CCM SDI trace, starting with 9.0 there is no SDI and simply pull the CallManager trace.
HTH,
Chris
Call dropping issue
Using CUCM version 7.1.5. The only way to read the SDI trace is VLT logs?, Please let me know is there is any other way. Thanks
-Murali
Call dropping issue
Chris
147
