Silver
Call failing- Mandatory information element missing
I have two sites calling the same destination
Site A calls Site C
Site B calls Site C
Site A can call other sites ok but fails when calling Site C
Site B can call any where
Calls to site C terminate on the same Rouer regardless of calling from Site A or B
GW`s using H323
Site A debug
Calling Party Number i = 0x0081, Number'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, Number'
Jul 2 11:29:12.149 CET: ISDN Se0/0/1:15 Q931: TX -> FACILITY pd = 8 callref = 0x0E53
Jul 2 11:29:12.165 CET: ISDN Se0/0/1:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x8E53
Channel ID i = 0xA98382
Exclusive, Channel 2
Jul 2 11:29:12.181 CET: ISDN Se0/0/1:15 Q931: RX <- STATUS pd = 8 callref = 0x8E53
Cause i = 0x81E0 - Mandatory information element missing
Call State i = 0x09
Jul 2 11:29:12.185 CET: ISDN Se0/0/1:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x0E53
Cause i = 0x82E0 - Mandatory information element missing
Jul 2 11:29:12.213 CET: ISDN Se0/0/1:15 Q931: RX <- RELEASE pd = 8 callref = 0x8E53
Jul 2 11:29:12.217 CET: ISDN Se0/0/1:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x0E53
Site B debug
Channel ID i = 0xA18384
Preferred, Channel 4
Jul 2 13:02:52.657 CET: ISDN Se0/0/1:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x8F1D
Channel ID i = 0xA98384
Exclusive, Channel 4
Jul 2 13:02:52.797 CET: ISDN Se0/0/1:15 Q931: RX <- FACILITY pd = 8 callref = 0x8F1D
Facility i = 0x91AA068001008201008B0100A11902010106042B0C0914300E0A01010A0102A006800438303030
Jul 2 13:02:52.937 CET: ISDN Se0/0/1:15 Q931: RX <- ALERTING pd = 8 callref = 0x8F1D
Facility i = 0x91AA06800100820100A10B02010106042B0C09018400
Progress Ind i = 0x8088 - In-band info or appropriate now available
Jul 2 13:02:53.277 CET: ISDN Se0/0/1:15 Q931: RX <- CONNECT pd = 8 callref = 0x8F1D
Facility i = 0x91AA06800100820100A10B02010206042B0C09028400
Progress Ind i = 0xA194 - Reserved value
Connected Number i = 0x0080, '8000'
Jul 2 13:02:53.281 CET: ISDN Se0/0/1:15 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x0F1D
Jul 2 13:02:56.369 CET: ISDN Se0/0/1:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x0F1D
Cause i = 0x8290 - Normal call clearing
Jul 2 13:02:56.397 CET: ISDN Se0/0/1:15 Q931: RX <- RELEASE pd = 8 callref = 0x8F1D
Jul 2 13:02:56.397 CET: ISDN Se0/0/1:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x0F1D
I noticed the Site A sends a Facility message before recievcing a CALL_PROC
What does Mandatory information element missing, I thought it was to do where CUCM puts messages. I configured up Site B H323 same as Site A and it works
Any ideas, where to look ?
thanks
I know this has been a whie ago, but have you figured this one out by any chance?
I see a very similar problem, although I'm dialing in through SIP trunks from two different locations to a third site, which connects to a local PBX through E1/ISDN.
And the same thing happens. One site does not send an empty FACILITY message, call gets through, the other site sends a FACILITY message without an information element and the call fails.
Having the same issue, calls
Having the same issue, calls come in on a sip trunk to cucm then routes some calls to PBX.  Getting same error.
2189
