Call failled between CUCME and PSTN
my CUCME is 12.4(13r)T  -  v8.0.
My CallManager Express  (which is in Germany) can not send or receive calls through the E1 link (30Channels).
Level 2its "OK", but the  call setup go to timeout. the provider switch not respond on call Setup..
after the call fealed the L2 go down and UP..
the error comes from the operator?? or is there a particular configuration in Germany?
thank's for your help
the output following show that state:
CCME-MASS-1# sh isdn status
Global ISDN Switchtype = primary-net5
ISDN Serial0/0/0:15 interface
        dsl 0, interface ISDN Switchtype = primary-net5
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 0 CCBs = 0
    The Free Channel Mask:  0xFFFF7FFF
    Number of L2 Discards = 1, L2 Session ID = 15
    Total Allocated ISDN CCBs = 0
the ccme configuration (truncated):
card type e1 0 0
l!
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
isdn switch-type primary-net5
voice service voip
!voice translation-rule 1
rule 1 // /030634153/ type any national
voice translation-rule 2
rule 1 /^030634153\(...\)/ /\1/
voice translation-rule 3
rule 1 // /00/
voice translation-rule 4
rule 2 /0/ //
voice translation-profile PSTN-Incoming
translate calling 3
translate called 2
voice translation-profile PSTN-Outgoing
translate calling 1
translate called 4
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31
i
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn timer T310 60000
isdn incoming-voice voice
no cdp enable
voice-port 0/0/0:15
dial-peer voice 1 pots
description External calls through PSTN
translation-profile outgoing PSTN-Outgoing
destination-pattern 0T
direct-inward-dial
port 0/0/0:15
forward-digits all
dial-peer voice 2 pots
description Incoming Call
translation-profile incoming PSTN-Incoming
incoming called-number .
direct-inward-dial
debug and call (last number are modify by x):
CCME-MASS-1#isdn test call interface serial 0/0/0:15 0033146xxxxxx
CCME-MASS-1#
Jun  2 13:04:49.911: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x0089 callID = 0x800A switch = primary-net5 interface = User
Jun  2 13:04:49.915: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0089
        Bearer Capability i = 0x8890
                Standard = CCITT
                Transfer Capability = Unrestricted Digital
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9839F
                Exclusive, Channel 31
        Called Party Number i = 0x81, '0033146xxxxxx'
                Plan:ISDN, Type:Unknown
Jun  2 13:04:50.915: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0089
                Standard = CCITT
Jun  2 13:04:53.911: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0089
                Standard = CCITT
Jun  2 13:04:54.911: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0089
                Standard = CCITT
Jun  2 13:04:55.911: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0089
                Standard = CCITT
Jun  2 13:04:56.911: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0089
                Standard = CCITT
Jun  2 13:04:57.911: ISDN Se0/0/0:15 **ERROR**: CCPCC_CallOrigination: SETUP timed-out (2nd T303) to NETWORK.  The SETUP failed.
CCME-MASS-1#
Jun  2 13:05:01.911: %ISDN-6-LAYER2DOWN: Layer 2 for Interface Se0/0/0:15, TEI 0 changed to down
Jun  2 13:05:01.911: ISDN Se0/0/0:15 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Jun  2 13:05:02.503: %ISDN-6-LAYER2UP: Layer 2 for Interface Se0/0/0:15, TEI 0 changed to up
Jun  2 13:05:02.511: ISDN Se0/0/0:15 Q931: TX -> RESTART pd = 8  callref = 0x0000
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Restart Indicator i = 0x80
        Channel ID i = 0xA98382
                Exclusive, Channel 2
        Channel ID i = 0xA98383
        Channel ID i = 0xA98384
                Exclusive, Channel 4
        Restart Indicator i = 0x80l
        Channel ID i = 0xA98385
                Exclusive, Channel 5
        Channel ID i = 0xA98386
                Exclusive, Channel 6
        Channel ID i = 0xA98387
                Exclusive, Channel 7
Jun  2 13:05:03.511: ISDN Se0/0/0:15 Q931: TX -> RESTART pd = 8  callref = 0x0000
Jun  2 13:05:10.511: %ISDN-6-LAYER2DOWN: Layer 2 for Interface Se0/0/0:15, TEI 0 changed to down
Jun  2 13:05:10.703: %ISDN-6-LAYER2UP: Layer 2 for Interface Se0/0/0:15, TEI 0 changed to up
1 REPLY
Re: Call failled between CUCME and PSTN
it's ok with goog cable and no framing-nocrc4 (in deutschland)
983
