Community Member
Call forward all on CME with analog trunks
I have a system setup as shown below where the reception phone has a button for extension 201 and one button each mapped to the incoming analog trunk lines. It was done this way because the owner wanted the phones to emulate the old style key system where the buttons where used to select an outgoing trunk line.
This being a small office the receptionist is not around all the time and they don't want to use an AA. They want to forward incoming calls to a cell phone as shown below where the cell phone numer is represented by 9185551111. Problem is that this config doesn't work. Incoming calls to 201 are forwarded but incoming calls to the analog lines (9185551212) are not.
How can I get this to work without rearchitecting the entire system?
Diego
voice-port 0/0/0
connection plar opx 9185551212
caller-id enable
voice-port 0/0/1
caller-id enable
voice-port 0/0/2
caller-id enable
ephone-dn 1 dual-line
number 201
pickup-group 1
label 201
description Reception
name Reception
call-forward all 9185551111
call-forward busy 299
call-forward noan 299 timeout 10
huntstop channel
ephone-dn 11 dual-line
number 9185551212
pickup-group 1
label Line 1
call-forward noan 3250 timeout 20
huntstop channel
no huntstop
hold-alert 45 originator
ephone-dn 12 dual-line
number 9185551212
pickup-group 1
label Line 2
preference 1
huntstop channel
no huntstop
ephone-dn 13 dual-line
number 9185551212
pickup-group 1
label Line 3
preference 2
huntstop channel
no huntstop
ephone-dn 50 dual-line
number 250
label 250
description Global Delivery Mailbox
name GDM
huntstop channel
ephone 1
mac-address AAAA.BBBB.CCCC
username "reception" password *****
type 7961
button 1:1 2:11 3:12 4:13
button 5:50
Hall of Fame Super Gold
Re: Call forward all on CME with analog trunks
You start with "show dialplan number XXX" where XXX is the number you set CFA for.
When you it's hitting the right DP, but still not working, you can do "debug voip dialpeer" and try a call.
Basically you gotta find which link of the chain is failing.
Community Member
I guess I did a bad job of explaining the situation. CFA does work to whatever number we enter. The problem is that it only works when the call is to the DN on button 1, in this case 201. However, 201 is only dialed by other extensions in the office so the CFA is really not needed for calls to 201. Since incoming calls from the outside don't ring 201, the CFA is never activated. We need CFA to activate for the other DNs mapped to buttons 2, 3 and 4.
Diego
Press the desired line button first, then set CFA as usual.
There is no way to set all buttons at once.
You can make an "fxo trunk" config so she can still monitor the lines individually, but actually all calls are going to a single DN, thus simplifying the working.
Community Member
Cool, I'll have to try that. One more thing though. When I press the line button I will get tone and the line will be in a seized state. Will the CFA button work at that moment?
Yes, as long the softkey template allows.
Community Member
Thanks for all your help. I meant to try what you suggested but I found the night-service feature to be easier to apply to this situation.
Diego
The thing is that night-service is inflexible while in small offices most often what is wanted is to turn on and or whatever forwarding as needed.
Community Member
Well, yes and no. You can use the "night-service code" command under telephony-service to be able to turn it on and off whenever you like which is what they want. In our case dialing *99 will toggle night-service mode.
The inflexible part is that I am also using "call-forward night-service 99185551212" on the DNs that receive the night bell service. This setting cannot be changed via the GUI only CLI which kinda makes it hard to change the number that calls are forwarded to.
Rgds,
Diego
374
