call forward and corlist
we have a Unified CME version 8.6:
CME#show telephony-service
CONFIG (Version=8.6)
Version 8.6
Max phoneload sccp version 17
Max dspfarm sccp version 18
Cisco Unified Communications Manager Express
We offer out customers VoIp service and our configuration is base on corlist to insolate each customer. Each one have a different number
associated in our E1 line. Our accounting is base on this number. Here are our configuration:
voice translation-rule 7
rule 1 /.*/ /968000001/
voice translation-rule 8
no rule 1 /968277843/ /21800/
rule 1 /968000001/ /21512/
ephone-dn  57  dual-line
no corlist incoming dn-llamadasFINTEGRA
corlist incoming dn-llamadasAMI2
voice translation-profile AMI2_in
translate called 8
voice translation-profile AMI2_out
translate calling 7
dial-peer cor custom
name AMI
dial-peer cor list llamadasAMI2
member AMI2
dial-peer cor list dn-llamadasAMI2
member INTERNO
member AMI2
dial-peer voice 4 pots
corlist outgoing llamadasAMI2
description PRIMARIO E1 AMI2
translation-profile incoming AMI2_in
translation-profile outgoing AMI2_out
destination-pattern 0T
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
incoming called-number 968000001
direct-inward-dial
port 0/0/0:15
number 20512 no-reg both
label ANTONIO
description 20512
name ANTONIO
call-forward all 0639XXXXX
hold-alert 30 originator
We notice that when a customer configures a forwarding call the corlist is not applied and the outgoing call use as calling number a random number associated to our E1 (we have 10 numbers). Logs shown that all dialer-peer are matched and are used randomly. For our accounting and billing this behaviour is not valid because forwarding calls used E1 numbers that are not associated to the corlist.
Here are the logs:
CCME#show debug
The following ISDN debugs are enabled on all DSLs:
debug isdn error is             ON.
debug isdn event is             ON.
DIALPEER:
  debug voip dialpeer error call is ON (filter is OFF)
  debug voip dialpeer error software is ON
  debug voip dialpeer inout is ON (filter is OFF)
voip translation-rule
  voip translation debugging is on (Filter is OFF)
CCAPI:
  debug voip ccapi error call is ON (filter is OFF)
  debug voip ccapi error software is ON
  debug voip ccapi inout is ON (filter is OFF)
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2013.11.06 14:59:41 =~=~=~=~=~=~=~=~=~=~=~=
CCME#
CCME#term mon
CCME#
CCME#
CCME#
Nov  6 14:06:57.401: ISDN Se0/0/0:15 EVENT: process_rxstate: ces/callid 1/0x23E0 calltype 2 CALL_INCOMING
Nov  6 14:06:57.401: ISDN Se0/0/0:15 EVENT: call_incoming: call_id 0x23E0, Guid = 8831CE22A3E1
Nov  6 14:06:57.401: //-1/xxxxxxxxxxxx/RXRULE/regxrule_get_profile_from_trunkgroup_internal:
   Voice port 0x4BE582C0 dsl=0 timeslot=1 does not belong to any trunk group
Nov  6 14:06:57.401: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=968355161, Called Number=968277843, Voice-Interface=0x4BE582C0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
Nov  6 14:06:57.405: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=4
Nov  6 14:06:57.405: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
   Calling Number=968355161, Called Number=968277843, Voice-Interface=0x0,
   Peer Info Type=DIALPEER_INFO_FAX
   Result=NO_MATCH(-1) After All Match Rules Attempt
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
Nov  6 14:06:57.405: //-1/xxxxxxxxxxxx/RXRULE/regxrule_profile_match_internal: Matched with rule 1 in ruleset 8
Nov  6 14:06:57.405: //-1/xxxxxxxxxxxx/RXRULE/sed_subst: Successful substitution; pattern=968277843 matchPattern=968277843 replacePattern=20512 replaced pattern=20512
Nov  6 14:06:57.405: //-1/xxxxxxxxxxxx/RXRULE/regxrule_subst_num_type: Match Type = none, Replace Type = none Input Type = national
Nov  6 14:06:57.405: //-1/xxxxxxxxxxxx/RXRULE/regxrule_subst_num_plan: Match Plan = none, Replace Plan = none Input Plan = isdn
Nov  6 14:06:57.405: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=20512, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=20512
   Result=Success(0) after DP_MATCH_DEST
Nov  6 14:06:57.405: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=20117
Nov  6 14:06:57.405: //-1/xxxxxxxxxxxx/RXRULE/regxrule_get_profile_from_trunkgroup_internal:
Nov  6 14:06:57.409: //-1/8831CE22A3E1/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=968355161
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=968277843
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Nov  6 14:06:57.409: //-1/8831CE22A3E1/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x4BE582C0, Call Info(
   Calling Number=968355161,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=968277843(TON=National, NPI=ISDN),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=4, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Nov  6 14:06:57.409: //-1/8831CE22A3E1/CCAPI/ccCheckClipClir:
   In: Calling Number=968355161(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
   Out: Calling Number=968355161(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
Nov  6 14:06:57.409: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Nov  6 14:06:57.409: :cc_get_feature_vsa malloc success
Nov  6 14:06:57.409:  cc_get_feature_vsa count is 1
Nov  6 14:06:57.409: :FEATURE_VSA attributes are: feature_name:0,feature_time:1305936024,feature_id:148560
Nov  6 14:06:57.409: //389928/8831CE22A3E1/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=968355161(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=968277843(TON=National, NPI=ISDN))
Nov  6 14:06:57.409: //-1/8831CE22A3E1/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x5079BF48; count=1
Nov  6 14:06:57.409: //-1/8831CE22A3E1/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x5059B160
Nov  6 14:06:57.413: //389928/8831CE22A3E1/CCAPI/cc_process_call_setup_ind:
   Event=0x4B37FEB8
Nov  6 14:06:57.413: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=968277843, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=968277843
   No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
Nov  6 14:06:57.413: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=968277843, saf_enabled=0, saf_dndb_lookup=1, dp_result=-1
Nov  6 14:06:57.413: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=NO_MATCH(-1)
Nov  6 14:06:57.413: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 968277843
Nov  6 14:06:57.413: //389928/8831CE22A3E1/CCAPI/ccCallSetContext:
   Context=0x4DD90DE8
   >>>>CCAPI handed cid 389928 with tag 4 to app "_ManagedAppProcess_Default"
Nov  6 14:06:57.413: //-1/8831CE22A3E1/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x5079BF48; count=1
Nov  6 14:06:57.413: //-1/8831CE22A3E1/RXRULE/regxrule_profile_translate_internal: number=968355161 type=national plan=isdn numbertype=calling
Nov  6 14:06:57.413: //-1/8831CE22A3E1/RXRULE/regxrule_get_RegXrule: Invalid translation ruleset tag=0
Nov  6 14:06:57.413: //-1/8831CE22A3E1/RXRULE/regxrule_profile_match_internal: Error: ruleset for calling number not found
Nov  6 14:06:57.413: //-1/8831CE22A3E1/RXRULE/regxrule_profile_translate_internal: No match: number=968355161 type=national plan=isdn
Nov  6 14:06:57.413: //-1/8831CE22A3E1/RXRULE/regxrule_profile_translate_internal: number= type=UNKNOWN plan=UNKNOWN numbertype=redirect-called
Nov  6 14:06:57.413: //-1/8831CE22A3E1/RXRULE/regxrule_profile_match_internal: Error: ruleset for redirect-called number not found
Nov  6 14:06:57.413: //-1/8831CE22A3E1/RXRULE/regxrule_profile_translate_internal: No match: number= type=UNKNOWN plan=UNKNOWN
Nov  6 14:06:57.413: //-1/8831CE22A3E1/RXRULE/regxrule_profile_translate_internal: number=968277843 type=national plan=isdn numbertype=called
Nov  6 14:06:57.413: //-1/8831CE22A3E1/RXRULE/regxrule_profile_match_internal: Matched with rule 1 in ruleset 8
Nov  6 14:06:57.413: //-1/8831CE22A3E1/RXRULE/sed_subst: Successful substitution; pattern=968277843 matchPattern=968277843 replacePattern=20512 replaced pattern=20512
Nov  6 14:06:57.413: //-1/8831CE22A3E1/RXRULE/regxrule_subst_num_type: Match Type = none, Replace Type = none Input Type = national
Nov  6 14:06:57.413: //-1/8831CE22A3E1/RXRULE/regxrule_subst_num_plan: Match Plan = none, Replace Plan = none Input Plan = isdn
Nov  6 14:06:57.413: //-1/8831CE22A3E1/RXRULE/regxrule_profile_translate_internal: xlt_number=20512 xlt_type=national xlt_plan=isdn
Nov  6 14:06:57.413: //389928/8831CE22A3E1/CCAPI/ccCallProceeding:
Nov  6 14:06:57.417: //-1/8831CE22A3E1/DPM/dpMatchPeersCore:
Nov  6 14:06:57.417: //-1/8831CE22A3E1/DPM/dpMatchSafModulePlugin:
   dialstring=20512, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
Nov  6 14:06:57.417: //-1/8831CE22A3E1/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   Result=SUCCESS(0)
Nov  6 14:06:57.417: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=20512, Called Number=20512, Peer Info Type=DIALPEER_INFO_SPEECH
Nov  6 14:06:57.417: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Nov  6 14:06:57.417: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   Calling Number=, Called Number=0639613460, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=0639XXXXXX
   dialstring=0639613460, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
   Result=SUCCESS(0)
     1: Dial-peer Tag=14
     2: Dial-peer Tag=19
     3: Dial-peer Tag=210
     4: Dial-peer Tag=7
     5: Dial-peer Tag=17
     6: Dial-peer Tag=200
     7: Dial-peer Tag=5
     8: Dial-peer Tag=21
     9: Dial-peer Tag=1
     10: Dial-peer Tag=3
     11: Dial-peer Tag=2
     12: Dial-peer Tag=18
     13: Dial-peer Tag=10
     14: Dial-peer Tag=15
     15: Dial-peer Tag=6
     16: Dial-peer Tag=20
     17: Dial-peer Tag=12
     18: Dial-peer Tag=13
     19: Dial-peer Tag=4
     20: Dial-peer Tag=11
Nov  6 14:06:57.417: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=20512, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
Nov  6 14:06:57.421: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Nov  6 14:06:57.421: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Nov  6 14:06:57.421: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Nov  6 14:06:57.421: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Nov  6 14:06:57.421: //-1/8831CE22A3E1/DPM/dpMatchPeersCore:
Nov  6 14:06:57.421: //-1/8831CE22A3E1/DPM/dpMatchSafModulePlugin:
   dialstring=20512, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
Nov  6 14:06:57.421: //-1/8831CE22A3E1/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Nov  6 14:06:57.421: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectingNumber:
   type=6 redirecting_number=20512
   Calling Number=, Called Number=0639XXXXXX, Peer Info Type=DIALPEER_INFO_SPEECH
   dialstring=0639XXXXXX, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
Nov  6 14:06:57.425: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=3
     2: Dial-peer Tag=2
     3: Dial-peer Tag=14
     4: Dial-peer Tag=10
     5: Dial-peer Tag=1
     6: Dial-peer Tag=6
     7: Dial-peer Tag=20
     8: Dial-peer Tag=13
     9: Dial-peer Tag=210
     10: Dial-peer Tag=5
     11: Dial-peer Tag=19
     12: Dial-peer Tag=17
     13: Dial-peer Tag=200
     14: Dial-peer Tag=18
     15: Dial-peer Tag=21
     16: Dial-peer Tag=4
     18: Dial-peer Tag=7
     19: Dial-peer Tag=11
     20: Dial-peer Tag=15
Nov  6 14:06:57.425: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectNumber:
  type=6  Original Called Number=20512, Called Number=20512, Calling Number=968355161, Calling DN=-1 Calling Id=389928,
   Redirect Number=0639613460, Redirect Reason=15
Nov  6 14:06:57.425: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=968355161, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=968355161
Nov  6 14:06:57.425: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=968355161, saf_enabled=0, saf_dndb_lookup=1, dp_result=-1
   Result=NO_MATCH(-1)
   Match Rule=DP_MATCH_DEST; Called Number=0639613460
   Result=SUCCESS(0)
     1: Dial-peer Tag=19
     2: Dial-peer Tag=3
     3: Dial-peer Tag=5
     4: Dial-peer Tag=11
     5: Dial-peer Tag=17
     6: Dial-peer Tag=210
     7: Dial-peer Tag=1
     8: Dial-peer Tag=7
     9: Dial-peer Tag=14
     10: Dial-peer Tag=13
     11: Dial-peer Tag=18
     12: Dial-peer Tag=10
     14: Dial-peer Tag=4
     15: Dial-peer Tag=6
     16: Dial-peer Tag=21
     17: Dial-peer Tag=15
     18: Dial-peer Tag=12
     19: Dial-peer Tag=200
     20: Dial-peer Tag=2
Nov  6 14:06:57.429: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Result=Partial Matches(1) after DP_MATCH_DEST
Nov  6 14:06:57.429: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=0639613460, saf_enabled=0, saf_dndb_lookup=1, dp_result=1
Nov  6 14:06:57.429: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=MORE_DIGITS_NEEDED(1)
Nov  6 14:06:57.429: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectingNumber:
Nov  6 14:06:57.429: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Nov  6 14:06:57.429: :cc_get_feature_vsa malloc success
Nov  6 14:06:57.429:  cc_get_feature_vsa count is 2
Nov  6 14:06:57.429: :FEATURE_VSA attributes are: feature_name:0,feature_time:1305944984,feature_id:148561
Nov  6 14:06:57.429: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
Nov  6 14:06:57.429:  feature_vsa is 4DD70090,featname is 0
Nov  6 14:06:57.429:  cc_get_feature_vsa count is 3
Nov  6 14:06:57.429: :FEATURE_VSA attributes are: feature_name:0,feature_time:1305943864,feature_id:148562
Nov  6 14:06:57.429: : Generating new featurevsa,inserting it
Nov  6 14:06:57.429:  feature call forward featname is 1
Nov  6 14:06:57.429: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Nov  6 14:06:57.429: :cc_free_feature_vsa freeing 4DD72390
Nov  6 14:06:57.429:  vsacount in free is 2
Nov  6 14:06:57.429: :FEATURE_VSA attributes are: feature_name:0,feature_time:1305944984,feature_id:148563
Nov  6 14:06:57.429: //-1/8831CE22A3E1/RXRULE/regxrule_profile_translate_internal: number=0639613460 type=unknown plan=unknown numbertype=redirect-target
Nov  6 14:06:57.433: //-1/8831CE22A3E1/RXRULE/regxrule_get_RegXrule: Invalid translation ruleset tag=0
Nov  6 14:06:57.433: //-1/8831CE22A3E1/RXRULE/regxrule_profile_match_internal: Error: ruleset for redirect-target number not found
Nov  6 14:06:57.433: //-1/8831CE22A3E1/RXRULE/regxrule_profile_translate_internal: No match: number=0639613460 type=unknown plan=unknown
Nov  6 14:06:57.433: //389928/8831CE22A3E1/CCAPI/ccGetTBCTCap:
   TGRM TBCT Enabled; TBCT Capability=0
Nov  6 14:06:57.433: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Nov  6 14:06:57.433: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Nov  6 14:06:57.433: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=NO_MATCH(-1)
Nov  6 14:06:57.433: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=0639613460, Called Number=, Voice-Interface=0x0,
Nov  6 14:06:57.433: //-1/8836AFFABC1E/DPM/dpMatchPeersCore:
Nov  6 14:06:57.437: //-1/8836AFFABC1E/DPM/dpMatchPeersCore:
Nov  6 14:06:57.437: //-1/8836AFFABC1E/DPM/dpMatchSafModulePlugin:
   dialstring=0639613460, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
Nov  6 14:06:57.437: //-1/8836AFFABC1E/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=210
     2: Dial-peer Tag=19
     3: Dial-peer Tag=5
     4: Dial-peer Tag=11
     5: Dial-peer Tag=1
     6: Dial-peer Tag=18
     7: Dial-peer Tag=13
     8: Dial-peer Tag=20
     9: Dial-peer Tag=3
     10: Dial-peer Tag=200
     11: Dial-peer Tag=2
     12: Dial-peer Tag=14
     15: Dial-peer Tag=12
     16: Dial-peer Tag=7
     17: Dial-peer Tag=17
     18: Dial-peer Tag=4
     19: Dial-peer Tag=21
     20: Dial-peer Tag=6
Nov  6 14:06:57.437: //-1/8836AFFABC1E/RXRULE/regxrule_translate_exist_internal: no rule for callback-number number
Nov  6 14:06:57.437: //-1/8836AFFABC1E/RXRULE/regxrule_profile_translate_internal: number=968355161 type=national plan=isdn numbertype=calling
Nov  6 14:06:57.437: //-1/8836AFFABC1E/RXRULE/regxrule_profile_match_internal: Matched with rule 1 in ruleset 102
Nov  6 14:06:57.437: //-1/8836AFFABC1E/RXRULE/sed_subst: Successful substitution; pattern=968355161 matchPattern=.* replacePattern=968277840 replaced pattern=968277840
Nov  6 14:06:57.437: //-1/8836AFFABC1E/RXRULE/regxrule_subst_num_type: Match Type = none, Replace Type = none Input Type = national
Nov  6 14:06:57.437: //-1/8836AFFABC1E/RXRULE/regxrule_subst_num_plan: Match Plan = none, Replace Plan = none Input Plan = isdn
Nov  6 14:06:57.437: //-1/8836AFFABC1E/RXRULE/regxrule_profile_translate_internal: xlt_number=968277840 xlt_type=national xlt_plan=isdn
Nov  6 14:06:57.437: //-1/8836AFFABC1E/RXRULE/regxrule_profile_translate_internal: number=0639613460 type=national plan=isdn numbertype=called
Nov  6 14:06:57.437: //-1/8836AFFABC1E/RXRULE/regxrule_get_RegXrule: Invalid translation ruleset tag=0
Nov  6 14:06:57.437: //-1/8836AFFABC1E/RXRULE/regxrule_profile_match_internal: Error: ruleset for called number not found
Nov  6 14:06:57.437: //-1/8836AFFABC1E/RXRULE/regxrule_profile_translate_internal: No match: number=0639613460 type=national plan=isdn
Nov  6 14:06:57.437: //-1/8836AFFABC1E/RXRULE/regxrule_profile_translate_internal: number= type=national plan=isdn numbertype=redirect-target
Nov  6 14:06:57.437: //-1/8836AFFABC1E/RXRULE/regxrule_profile_match_internal: Error: ruleset for redirect-target number not found
Nov  6 14:06:57.437: //-1/8836AFFABC1E/RXRULE/regxrule_profile_translate_internal: No match: number= type=national plan=isdn
Nov  6 14:06:57.437: //-1/8836AFFABC1E/RXRULE/regxrule_profile_translate_internal: number=20512 type=unknown plan=unknown numbertype=redirect-called
Nov  6 14:06:57.437: //-1/8836AFFABC1E/RXRULE/regxrule_profile_match_internal: Error: ruleset for redirect-called number not found
Nov  6 14:06:57.437: //-1/8836AFFABC1E/RXRULE/regxrule_profile_translate_internal: No match: number=20512 type=unknown plan=unknown
Nov  6 14:06:57.437: //389928/8831CE22A3E1/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=210, Params=0x4DD972B0, Progress Indication=NULL(0)
Nov  6 14:06:57.437: //-1/8831CE22A3E1/RXRULE/regxrule_vp_translate: No profile found in voice port or trunk group for outgoing direction
Nov  6 14:06:57.437: //-1/8831CE22A3E1/RXRULE/regxrule_vp_translate: calling_number=968277840 calling_octet=0x21
called_number=0639613460 called_octet=0xA1
redirect_number=20512 redirect_type=0 redirect_plan=0
Nov  6 14:06:57.437: //389928/8831CE22A3E1/CCAPI/ccCheckClipClir:
   In: Calling Number=968277840(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
   Out: Calling Number=968277840(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
   Destination Pattern=0T, Called Number=0639613460, Digit Strip=TRUE
   Calling Number=968277840(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=0639613460(TON=National, NPI=ISDN),
   Redirect Number=20512, Display Info=
   Account Number=, Final Destination Flag=TRUE,
   Guid=8836AFFA-4623-11E3-BC1E-AD9C1133E1AD, Outgoing Dial-peer=210
Nov  6 14:06:57.437: //389928/8831CE22A3E1/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=968277840
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=0639613460
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=73
   cisco-rdn=20512
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=15   fwd_final_type =0
Nov  6 14:06:57.441: //389928/8831CE22A3E1/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x4BE582C0, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=968277840,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=0639613460(TON=National, NPI=ISDN), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=210, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Nov  6 14:06:57.441: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Nov  6 14:06:57.441: :cc_get_feature_vsa malloc success
Nov  6 14:06:57.441:  cc_get_feature_vsa count is 3
Nov  6 14:06:57.441: :FEATURE_VSA attributes are: feature_name:0,feature_time:1305944984,feature_id:148564
Nov  6 14:06:57.441: //389929/8831CE22A3E1/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Nov  6 14:06:57.441: //389929/8831CE22A3E1/CCAPI/ccCallSetContext:
   Context=0x4DD97260
Nov  6 14:06:57.441: //389928/8831CE22A3E1/CCAPI/ccSaveDialpeerTag:
Nov  6 14:06:57.441: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
Nov  6 14:06:57.441:  feature call forward featname is 1
Nov  6 14:06:57.441:  feature_vsa is 4DD72390,featname is 0
Nov  6 14:06:57.441:  cc_get_feature_vsa count is 4
Nov  6 14:06:57.441: :FEATURE_VSA attributes are: feature_name:0,feature_time:1305939608,feature_id:148565
Nov  6 14:06:57.441: : Generating new featurevsa,inserting it
Nov  6 14:06:57.445: ISDN Se0/0/0:15 EVENT: process_pri_call: call id 0xBD4A, number 639613460, Guid 8836AFFABC1E, speed 0, call type VOICE, redial No, CSM call No, pdata Yes
Nov  6 14:06:57.525: ISDN Se0/0/0:15 EVENT: process_rxstate: ces/callid 1/0xBD4A calltype 2 CALL_PROCEEDING
Nov  6 14:06:57.525: //389929/8831CE22A3E1/CCAPI/cc_api_call_proceeding:
   Interface=0x4BE582C0, Progress Indication=NULL(0)
Nov  6 14:07:00.001: ISDN Se0/0/0:15 EVENT: process_rxstate: ces/callid 1/0xBD4A calltype 2 CALL_PROGRESS
Nov  6 14:07:00.005: //389929/8831CE22A3E1/CCAPI/cc_api_call_alert:
   Interface=0x4BE582C0, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1)
   Call Entry(Retry Count=0, Responsed=TRUE)
Nov  6 14:07:00.005: //389928/8831CE22A3E1/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Nov  6 14:07:00.005: //389928/8831CE22A3E1/CCAPI/ccConferenceCreate:
   (confID=0x4E03FFD8, callID1=0x5F328, gcid=8831CE22-462311E3-A3E10024-C4AF7D40, tag=0x0)
Nov  6 14:07:00.005: //389929/8831CE22A3E1/CCAPI/ccConferenceCreate:
   (confID=0x4E03FFD8, callID2=0x5F329, gcid=8831CE22-462311E3-A3E10024-C4AF7D40, tag=0x0)
   Conference Id=0x4E03FFD8, Call Id1=389928, Call Id2=389929, Tag=0x0
Nov  6 14:07:00.005: //389928/8831CE22A3E1/CCAPI/cc_api_bridge_done:
   Conference Id=0x77A1, Source Interface=0x4BE582C0, Source Call Id=389928,
   Destination Call Id=389929, Disposition=0x0, Tag=0xFFFFFFFF
Nov  6 14:07:00.009: //389929/8831CE22A3E1/CCAPI/cc_api_bridge_done:
   Conference Id=0x77A1, Source Interface=0x4BE582C0, Source Call Id=389929,
   Destination Call Id=389928, Disposition=0x0, Tag=0xFFFFFFFF
Nov  6 14:07:00.009: //389928/8831CE22A3E1/CCAPI/cc_generic_bridge_done:
Nov  6 14:07:00.009: //389928/8831CE22A3E1/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x77A1, Destination Call Id=389929)
Nov  6 14:07:00.009: //389929/8831CE22A3E1/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x77A1, Destination Call Id=389928)
Nov  6 14:07:00.009: //389928/8831CE22A3E1/CCAPI/cc_api_caps_ind:
   Destination Interface=0x4BE582C0, Destination Call Id=389929, Source Call Id=389928,
   Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
   Modem=0x2, Codec Bytes=160, Signal Type=2)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
Nov  6 14:07:00.009: //389929/8831CE22A3E1/CCAPI/cc_api_caps_ind:
   Destination Interface=0x4BE582C0, Destination Call Id=389928, Source Call Id=389929,
Nov  6 14:07:00.009: //389929/8831CE22A3E1/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=4225)
Nov  6 14:07:00.009: //389928/8831CE22A3E1/CCAPI/cc_api_caps_ack:
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=2565)
Nov  6 14:07:00.009: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=968277840, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=968277840
Nov  6 14:07:00.009: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Nov  6 14:07:00.009: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
   Calling Number=, Called Number=639613460, Peer Info Type=DIALPEER_INFO_SPEECH
Nov  6 14:07:00.013: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=639613460
Nov  6 14:07:00.013: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Nov  6 14:07:00.013: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
Nov  6 14:07:00.013: //389929/8831CE22A3E1/CCAPI/cc_api_voice_mode_event:
   Call Id=389929
   Call Entry(Context=0x4DD97260)
Nov  6 14:07:00.013: //389928/8831CE22A3E1/CCAPI/cc_api_voice_mode_event:
   Call Id=389928
   Call Entry(Context=0x4DD90DE8)
Nov  6 14:07:00.013: //389928/8831CE22A3E1/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x77A1, Call Id1=389928, Call Id2=389929
CCME#
CCME#
CCME#
CCME#
CCME#
CCME#
CCME#ter no mon
CCME#
1 REPLY
Hello again,
I have create a new dialer-peer to match to route forwarding calls:
dial-peer voice 104 pots
description ROUTING para desvio AMI2
destination-pattern 639XXXXXX
port 0/0/0:15
label ANTONIO
description 20512
name ANTONIO
call-forward all 639XXXXXX
Now I have a new problem. Forwarding call match dial-peer voice 104 becasue the call-forward number that start by 0.
Every translations are Ok but the in the outgoing ISDN packet there no called number:
v  6 18:10:06.497: ISDN Se0/0/0:15 EVENTd: isdn_get_guid: Got Guid 7FF801FDBEE9
Nov  6 18:10:06.497: ISDN Se0/0/0:15 EVENT: process_pri_call: call id 0xBD84, number , Guid 7FF801FDBEE9, speed 0, call type VOICE, redial No, CSM call No, pdata YesReceived pdata len 0xE3 data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
Nov  6 18:10:06.501: ISDN Se0/0/0:15 EVENTd: process_pri_call: No name in GTD
Nov  6 18:10:06.501: ISDN Se0/0/0:15 EVENTd: fill_cid_table_voice: Still don't know a number to redial.
Nov  6 18:10:06.501: ISDN Se0/0/0:15 EVENTd: fill_cid_table_voice: Created entry call_id 0xBD84, speed 64, remote , calling 968277830
Nov  6 18:10:06.501: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x2 0x1, Calling num 968277830
Nov  6 18:10:06.501: ISDN Se0/0/0:15 EVENTd: Packet to CC Data
Nov  6 18:10:06.501:           4D0001BD841E0404800010A318040003
Nov  6 18:10:06.501:           00FF6C0C028183393638323737383330
Nov  6 18:10:06.501:           7002020104038090A318030003006C0B
Nov  6 18:10:06.501:           2183393638323737383330740800008F
Ok. Then I have created a translate that change 639XXXXXX to 0639XXXXXX but my ISDN service provider tell
that can not route this call because start by 0.... Why 0 number is not dropped?.
Nov  6 18:33:59.273: ISDN Se0/0/0:15 EVENTd: isdn_get_guid: Got Guid D5F836E3BF32
Nov  6 18:33:59.273: ISDN Se0/0/0:15 EVENT: process_pri_call: call id 0xBD8B, number 0639616460, Guid D5F836E3BF32, speed 0, call type VOICE, redial No, CSM call No, pdata YesReceived pdata len 0xE3 data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
Nov  6 18:33:59.277: ISDN Se0/0/0:15 EVENTd: process_pri_call: No name in GTD
Nov  6 18:33:59.277: ISDN Se0/0/0:15 EVENTd: fill_cid_table_voice: Created entry call_id 0xBD8B, speed 64, remote 0639XXXXXX, calling 968277830
Nov  6 18:33:59.277: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x2 0x1, Calling num 968277830
Nov  6 18:33:59.277: ISDN Se0/0/0:15 EVENTd: Packet to CC Data
Nov  6 18:33:59.277:           4D0001BD8B280404800010A318040003
Nov  6 18:33:59.277:           00FF6C0C028183393638323737383330
Nov  6 18:33:59.281: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x3E0A
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
202
