call forward and internal calls
arnulf.blattl
is there any way a phone user can setup "call-forward all" but internal dn phones can still ring the phone?
i know you can block call-forward for internal calls, but calls are disconnected then and do not ring the phone.
lg
Arnulf
Rob Huffman
Hi Arnulf,
There is a  feature, which is called "CFA Destination Override". Have a look;
Cisco  Unified CallManager provides a service parameter (CFA Destination  Override) that allows the administrator to override Call Forward All  (CFA) when the target of the CFA calls the initiator of the CFA, so the  CFA target can reach the initiator for important calls. In other words,  when the user to whom calls are being forwarded (the target) calls the  user whose calls are being forwarded (the initiator), the phone of the  initiator rings instead of call forwarding back to the target. The  override works whether the CFA target phone number is internal or  external.
When  the CFA Destination Override service parameter is set to False (the  default value), no override occurs. Ensure the service parameter is set  to True for CFA override to work. See Service Parameters Configuration  in the Cisco Unified CallManager Administration Guide, Release 5.0(4),  for information about configuring service parameters.
Note CFA  override only takes place if the CFA destination matches the calling  party and the CFA Destination Override service parameter is set to True.  If the service parameter is set to True and the calling party does not  match the CFA destination, CFA override does not take place, and the CFA  remains in effect.
From this CUCM doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a0080739bb8.html
This only  works from the phone that the Call Forward All is directed to
Hope this helps!
Rob
Hi.
I should have sayed this is for cucme we have some UC500 here.
Is there any possibility in cucme?
thanks
Arnulf
Rob,
The link in this post doesn't work.  Takes me to a cisco page not found...
Mark
Hey Mark,
I think there are some issues @ Cisco today, I can't get to the Bug Search Tool either;
Try;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_0_1/ccmsys/a08ipph.html#wp1170014
Cheers!
Rob
"Show a little faith, there's magic in the night" - Springsteen
