Community Member
Call-forward/call-transfer problem cisco CME
i have set up an router with callmanager express 3.1 witch is connected to a sip service provider via a sip trunk, ingoing and outgoing calls work just fine but when i try to forward calls i can only use full-consult as transfer-system, and i want to use blind or full-blind.
internally it works with both blind and consult but when i try to transfer a call from the outside to an other internal phone with full-blind it just hangs up.
I see that it sends a sip refer message to the provider and gets a error message back (405 method not allowed) when i use full-blind as transfer-system. but with full-consult that works it doesnt...?
does it really need to contact the sip provider to foward a call from one internal phone to an other?
i think its because of this problem that i can?t get call-forward noa and busy to work either...
hope someone can help me with this annoying problem...
here is my relevant config:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
redirect ip2ip
sip
bind control source-interface Loopback0
bind media source-interface Loopback0
registrar server expires max 1500 min 500
voice translation-rule 1
rule 1 /^0/ //
voice translation-rule 3
rule 1 /^4/ /004/
voice translation-rule 1000
rule 1 /\(^7...\)/ /******nr*******/
voice translation-profile 100
translate calling 1000
voice translation-profile PROFILE1
translate called 1
voice translation-profile PROFILE3
translate called 3
dial-peer voice 1 voip
description OUTGOING CALLS
translation-profile outgoing PROFILE1
service session
destination-pattern 0T
voice-class codec 1
session protocol sipv2
session target sip-server
dtmf-relay rtp-nte
clid restrict
clid restrict
no vad
dial-peer voice 2 voip
description OUTGOING CALLS +4
translation-profile outgoing PROFILE3
service session
destination-pattern 4.........
voice-class codec 1
dtmf-relay rtp-nte
clid restrict
clid restrict
no vad
gateway
timer receive-rtp 1200
sip-ua
max-forwards 30
registrar ipv4:******IP***expires 3600
registrar ipv4:******IP*** expires 3600 tcp secondary
sip-server ipv4:******IP***
telephony-service
max-ephones 10
max-dn 150
ip source-address 192.168.0.1 port 2000
auto assign 1 to 4
auto assign 50 to 70
calling-number local
timeouts interdigit 5
system message ********
url services http://phone-xml.berbee.com/menu.xml
network-locale NO
create cnf-files version-stamp 7960 May 15 2007 08:57:31
dialplan-pattern 1 ****nr***.... extension-length 4
dialplan-pattern 2 ****nr***... extension-length 3
max-conferences 4
call-forward pattern .T
dn-webedit
time-webedit
transfer-system full-blind
transfer-pattern .T
secondary-dialtone 0
//Kristoffer
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Call-forward/call-transfer problem cisco CME
the thing is that older CME like your, will always contact the SIP provider for transfers, even as you noted, that would not be necessary.
If you upgrade to CME 4.0 or 4.1 there is a new command "no supplementary-service sip moved-temporarily" that will avoid the above. Please see CME documentation about this.
Community Member
I will try cme 4 as soon as a get a new router, it seems that the 1841 doesnt support CME 4.0... at least not if the feature navigator is right.
thanks for your quick answer!
No the 1841 does not support CME. Even for older CME, seems like that on 1841, the feature was there by mistake as it has never been advertised.
As a courtesy to those providing answers, please rate all useful posts using the scrollbox below!
Community Member
Do you know which ios release that includes cme 4.1? (for a 2621XM or 2811 routers)
the feature navigator or software advisor doesnt seem to be updated...
it seems that they support it according to this document:
http://www.cisco.com/en/US/customer/products/sw/voicesw/ps4625/prod_installation_guide09186a00807aae21.html
258
