Call forward external with no ring-back
Hi all, on my CCM 8.6.2 when a user set the CFA on external number (ex. mobile phone) who call the extension from outside don't hear the ring-back.
Ring-back: internal DN -> internal DN (with external CFA)
No ring-back: outside caller -> voicegateway -> internal DN (with external CFA)
on answer all is working and I can hear both voice.
Green
What type of gateway are you using.
SIP, H323 , MGCP.
Can you post the the config.
Alex
Regards, Alex. Please rate useful posts.
The gateway is H323 (2921), and the call coming in by E1 line and come out with the same E1 controller.
this is my conf:
dial-peer voice 10 pots
translation-profile incoming zero
service num2name
translate-outgoing calling 3
translate-outgoing called 3
incoming called-number .T
fax rate disable
supplementary-service pass-through
direct-inward-dial
dial-peer voice 33 voip
destination-pattern 1234567..
session target ipv4:192.168.55.1
dtmf-relay rtp-nte cisco-rtp h245-alphanumeric
codec g711alaw
dial-peer voice 32 pots
destination-pattern 0T
port 0/1/0:15
Incoming dial-peer (from outside): 10
dial-peer to CM(8.6): 33
dial-peer to outside (to reach extenal number): 32
On the Call Manager (192.168.55.1) I have a DN with CFA to external number
Any suggestion?
Hall of Fame Super Silver
Add the following to your pots dial-peers:
progress_ind setup enable 3
progress_ind progress enable 8
HTH,
Chris
Thanks Chris but this not solve my issue.
When I debug isdn q931 I see this two lines:
    Locking Shift to Codeset 6
    Codeset 6 IE 0x1A  i = 0xC40C
I don't know if can help because I don't know what they means.
Enrico.
Hall of Fame Super Gold
These have nothing to do with your problem. Check following document:
http://www.cisco.com/en/US/tech/tk1077/technologies_tech_note09186a0080094c33.shtml
The strange things is that it works with every number except one that the customer need!! If I call directly I hear the ringback but not when I forward a call to it.
I my debug I see:
voicegw_ia#
Mar  5 16:41:24.827: ISDN Se0/1/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0030
    Sending Complete
    Bearer Capability i = 0x8090A3
        Standard = CCITT
        Transfer Capability = Speech
        Transfer Mode = Circuit
        Transfer Rate = 64 kbit/s
    Channel ID i = 0xA1838D
        Preferred, Channel 13
    Calling Party Number i = 0x0181, 'my mobile phone'
        Plan:ISDN, Type:Unknown
    Called Party Number i = 0xA1, 'PRI number with CFA'
        Plan:ISDN, Type:National
    High Layer Compat i = 0x9181
Mar  5 16:41:24.827: ISDN Se0/1/0:15 Q931: Received SETUP  callref = 0x8030 callID = 0x0AC0 switch = primary-net5 interface = User
Mar  5 16:41:24.847: ISDN Se0/1/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x8030
    Channel ID i = 0xA9838D
        Exclusive, Channel 13
Mar  5 16:41:24.855: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 3473292620
Mar  5 16:41:24.859: ISDN Se0/1/0:15 Q931: Sending SETUP  callref = 0x0B1C callID = 0x8D70 switch = primary-net5 interface = User
Mar  5 16:41:24.859: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0B1C
        Standard = CCITT
    Channel ID i = 0xA98382
        Exclusive, Channel 2
    Progress Ind i = 0x8183 - Origination address is non-ISDN
    Calling Party Number i = 0x0081, 'my mobile phone'
        Plan:Unknown, Type:Unknown
    Called Party Number i = 0x80, 'destination without ringback'
Mar  5 16:41:24.895: ISDN Se0/1/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0x8B1C
voicegw_ia#
voicegw_ia#
voicegw_ia#
voicegw_ia#
Mar  5 16:41:30.479: ISDN Se0/1/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8B1C
    Progress Ind i = 0x8482 - Destination address is non-ISDN
voicegw_ia#
voicegw_ia#
Enrico,
try
under voip DP that points to CM.
This is what I have:
destination-pattern 12345678..
session target ipv4:192.168.xx.1
codec g711ulaw
But I hear no ringback on forwarded call (to outside)
What about the pots DP ?
These are my dial-peer, the strange things is that with some number it works
// outgoing DP
port 0/1/0:15
// incoming DP
fax rate disable
direct-inward-dial
You should see that with other numbers, alerting is received on the outbound call, and that causes the tone to be heard.
Can you try 'voice call send-alert'.
I found that the number where I forward the call to is a voip account forwarded to a mobile number.
So:
My PRI -> My internal phone (with CFA) -> extenal VOIP account (through same PRI) (with CFA on mobile) -> mobile phone
So the situation is a bit strange (two nested CFA ), if I remove the last forward on mobile all works.
Maybe isn't a problem on the Cisco side....
1515
