08-28-2013 01:24 PM - edited 03-16-2019 07:05 PM
Hello All,
Unable to call forward number from cisco phone but im able to dial/reach the same number from the same Cisco phone. Only call forward is not working. Line, Device and Callforward CSS are same. Is there something need to do in service parameter?. Thanks for your assistance.
-Murali
08-28-2013 01:43 PM
CUCM version???
What's the CFA CSS activation policy??
If you have it.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
08-28-2013 02:43 PM
Hello Jaime,
Its "with configured CSS".
Murali
08-28-2013 05:49 PM
What happens when you try to enable it on the phone??
What do you see? hear?
java
08-29-2013 12:12 AM
Hi Murali.
As asked from Jaime , please specify CUCM version and IP Phone model
Carlo
Please rate all helpful posts
"The more you help the more you learn"
08-30-2013 05:27 AM
CUCM version is 7.5, when im CFW from CUCM the phone is displaying the message "call forward to XXXXXXX" but when i try to call forward from the phone getting message "precedence level exceeded"
08-30-2013 06:17 AM
Hi Murali.
Try to change the CSS forwarding method in "line/device CSS" and see if it makes the difference
Carlo
