Call forward history in IP phone
CUCM 7.1.5 - IP Phone 7962, If call is being forwarded to a mobile number, the history of the calls is not seen in the IP phone and on the mobile phone only the PSTN number of the IP Phone is seen, so if there is a missed call in the mobile, we are not able to check who has made the call becuse only IP phone PSTN number is displayed as missed call and who actually called is not know, how do we find that or what options are do we have to enable on the IP Phone and CUCM to get to call forwarded history on the IP phone.
1 REPLY
VIP Super Bronze
Re: Call forward history in IP phone
You have two separate issues here:
  1. Call histories (received/placed/missed) are currently stored on the observed target. You are not seeing the call history on the IP Phone because the call never alerted on it due to call forwarding. The same occurs if you unplug a phone and make calls to the DN. When you plug that phone back in missed calls will not appear from a device that was unregistered at the time of the call start. This is an architectural issue with UCM.
    Workaround: You can use Mobile Connect instead of call forwarding. If you use Mobile Connect, the call will ring both destinations simultaneously.
  2. The PSTN circuit is likely filtering the values you are allowed to send for ANI on an outbound call. If you have a PRI this can be observed using 'debug isdn q931'. All you can do is confirm that you are sending the correct information (Mobile Connect will do this for you by default). There is nothing you can do if the carrier is overwriting the information you send, except complain to them. The rules vary by carrier and region. In the US most CLECs will allow you to send anything you want while most ILECs will not.
Please remember to rate helpful responses and identify helpful or
373
