Call forward information
lcelinski
I have CUCM 9.1 with H.323 gateway connected by BRI ports to external provider.
Scenario:
1. User A (cell phone) calls user B (Cisco IP Phone)
2. User B forward all calls to user C (cell phone)
3. Call is established between User A and User C but User C sees calling number of user B. What should I do to user C sees calling number of user A?
Any idea?
H.323 Gateway, "Call Routing Information - Outbound Calls" -> "Calling Party Selection" -> "Last Redirect Number (External)"
2 Accepted Solutions
Apr 29 11:34:13.279: ISDN BR0/1/0 Q931: TX -> SETUP pd = 8  callref = 0x43
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0x8A
                Exclusive, B2
        Calling Party Number i = 0x1181, '0504504504'
                Plan:ISDN, Type:International
        Called Party Number i = 0x80, '603603603'
                Plan:Unknown, Type:Unknown
        Sending Complete
Apr 29 11:34:13.319: ISDN BR0/1/0 Q931: RX <- CALL_PROC pd = 8  callref = 0xC3
        Channel ID i = 0x8A
                Exclusive, B2
Apr 29 11:34:13.435: ISDN BR0/1/0 Q931: RX <- DISCONNECT pd = 8  callref = 0xC3
        Cause i = 0x8095 - Call rejected
Apr 29 11:34:13.435: ISDN BR0/1/0 Q931: TX -> RELEASE pd = 8  callref = 0x43
Apr 29 11:34:13.459: ISDN BR0/1/0 Q931: RX <- RELEASE_COMP pd = 8  callref = 0xC3
the call is rejected by the provider as Calling Party Number i = 0x1181, '0504504504' is not their DID number. If we include their number "897897897" as a Redirecting Number in the setup message sent out, then i hope they will accept the call.
Please add the commend "isdn outgoing ie redirecting-number" under BRI interface BRI0/1/0.
You can collect the debug isdn q931 once again after issuing the above command to verify whether the redirecting number is sent out or not.
//Suresh
Please rate all the helpful posts
//Suresh Please rate all the useful posts.
have you configured the 'External Phone number mask' under DN configuration? if yes, then you may try configuring the "Redirecting Party Transformation CSS" to translate the internal number to DID number
11 Replies 11
Could you please set the Calling Party Selection to "Originator" and check?
also you would need to check the "Redirecting Number IE Delivery - Outbound" box as your provider may look for the valid DID number for a outbound call setup message.
in case if the calls still not working, please collect the debug isdn q931 for a test call and attach the output here.
//Suresh
Please see the following debug output (user A- 48504504504, user B- 897897897, user C- 603603603)
Apr 29 10:54:55.119: ISDN BR0/1/1 Q931: RX <- SETUP pd = 8  callref = 0x13
                Standard = CCITT
        Channel ID i = 0x89
                Exclusive, B1
        Calling Party Number i = 0x1180, '48504504504'
        Sending Complete
        Called Party Number i = 0xA1, '897897897'
                Plan:ISDN, Type:National
Apr 29 10:54:55.127: ISDN BR0/1/1 Q931: TX -> CALL_PROC pd = 8  callref = 0x93
        Channel ID i = 0x89
                Exclusive, B1
Apr 29 10:54:55.179: ISDN BR0/1/0 Q931: Applying typeplan for sw-type 0x1 is 0x2 0x0, Calling num 897897897
Apr 29 10:54:55.179: ISDN BR0/1/0 Q931: Sending SETUP  callref = 0x0033 callID = 0x9C7E switch = basic-net3 interface = User
Apr 29 10:54:55.179: ISDN BR0/1/0 Q931: TX -> SETUP pd = 8  callref = 0x33
                Standard = CCITT
        Channel ID i = 0x8A
                Exclusive, B2
        Calling Party Number i = 0x2081, '897897897'
                Plan:Unknown, Type:National
        Sending Complete
Apr 29 10:54:55.215: ISDN BR0/1/0 Q931: RX <- CALL_PROC pd = 8  callref = 0xB3
        Channel ID i = 0x8A
                Exclusive, B2
Apr 29 10:54:58.179: ISDN BR0/1/1 Q931: TX -> ALERTING pd = 8  callref = 0x93
        Progress Ind i = 0x8181 - Call not end-to-end ISDN, may have in-band info
Apr 29 10:55:00.195: ISDN BR0/1/0 Q931: RX <- PROGRESS pd = 8  callref = 0xB3
        Progress Ind i = 0x8088 - In-band info or appropriate now available
Apr 29 10:55:00.203: ISDN BR0/1/0 Q931: RX <- ALERTING pd = 8  callref = 0xB3
Apr 29 10:55:01.295: ISDN BR0/1/1 Q931: RX <- DISCONNECT pd = 8  callref = 0x13
        Cause i = 0x8090 - Normal call clearing
Apr 29 10:55:01.295: ISDN BR0/1/1 Q931: TX -> RELEASE pd = 8  callref = 0x93
Apr 29 10:55:01.319: ISDN BR0/1/1 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x13
Apr 29 10:55:01.367: ISDN BR0/1/0 Q931: TX -> DISCONNECT pd = 8  callref = 0x33
Apr 29 10:55:01.387: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8  callref = 0xB3
Apr 29 10:55:01.387: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x33
did you apply the settings i mentioned above and reset the gateway?
Yes, do you have any other idea?
Sorry, wrong outputs. Plese see the following.
Apr 29 11:34:09.243: ISDN BR0/1/0 Q931: TX -> DISCONNECT pd = 8  callref = 0x42
        Cause i = 0x80A6 - Network out of order
Apr 29 11:34:09.247: ISDN BR0/1/1 Q931: TX -> DISCONNECT pd = 8  callref = 0x97
Apr 29 11:34:09.267: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8  callref = 0xC2
Apr 29 11:34:09.267: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x42
Apr 29 11:34:09.271: ISDN BR0/1/1 Q931: RX <- RELEASE pd = 8  callref = 0x17
Apr 29 11:34:09.271: ISDN BR0/1/1 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x97
Apr 29 11:34:13.223: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8  callref = 0x49
                Standard = CCITT
        Channel ID i = 0x89
                Exclusive, B1
        Sending Complete
Apr 29 11:34:13.227: ISDN BR0/1/0 Q931: TX -> CALL_PROC pd = 8  callref = 0xC9
        Channel ID i = 0x89
                Exclusive, B1
Apr 29 11:34:13.279: ISDN BR0/1/0 Q931: Applying typeplan for sw-type 0x1 is 0x1 0x1, Calling num 0504504504
Apr 29 11:34:13.279: ISDN BR0/1/0 Q931: Sending SETUP  callref = 0x0043 callID = 0x9C8E switch = basic-net3 interface = User
                Standard = CCITT
        Channel ID i = 0x8A
                Exclusive, B2
        Sending Complete
        Channel ID i = 0x8A
                Exclusive, B2
Apr 29 11:34:13.531: ISDN BR0/1/0 Q931: Applying typeplan for sw-type 0x1 is 0x1 0x1, Calling num 0504504504
Apr 29 11:34:13.531: ISDN BR0/1/0 Q931: Sending SETUP  callref = 0x0044 callID = 0x9C8F switch = basic-net3 interface = User
Apr 29 11:34:13.531: ISDN BR0/1/0 Q931: TX -> SETUP pd = 8  callref = 0x44
                Standard = CCITT
        Channel ID i = 0x8A
                Exclusive, B2
        Sending Complete
Apr 29 11:34:13.571: ISDN BR0/1/0 Q931: RX <- CALL_PROC pd = 8  callref = 0xC4
        Channel ID i = 0x8A
                Exclusive, B2
Apr 29 11:34:13.675: ISDN BR0/1/0 Q931: RX <- DISCONNECT pd = 8  callref = 0xC4
Apr 29 11:34:13.679: ISDN BR0/1/0 Q931: TX -> RELEASE pd = 8  callref = 0x44
Apr 29 11:34:13.703: ISDN BR0/1/0 Q931: RX <- RELEASE_COMP pd = 8  callref = 0xC4
Apr 29 11:34:13.723: ISDN BR0/1/0 Q931: TX -> DISCONNECT pd = 8  callref = 0xC9
Apr 29 11:34:13.743: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8  callref = 0x49
Apr 29 11:34:13.747: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8  callref = 0xC9
                Standard = CCITT
        Channel ID i = 0x8A
                Exclusive, B2
        Sending Complete
        Channel ID i = 0x8A
                Exclusive, B2
//Suresh
I have internal number associate with IP Phone (9895757). It seems that I should translate this local number to public number. Do you know where I can do this?
Apr 29 13:38:30.249: ISDN BR0/1/1 Q931: RX <- SETUP pd = 8  callref = 0x32
                Standard = CCITT
        Channel ID i = 0x89
                Exclusive, B1
        Sending Complete
Apr 29 13:38:30.253: ISDN BR0/1/1 Q931: TX -> CALL_PROC pd = 8  callref = 0xB2
        Channel ID i = 0x89
                Exclusive, B1
Apr 29 13:38:30.313: ISDN BR0/1/0 Q931: Applying typeplan for sw-type 0x1 is 0x1 0x1, Calling num 0504504504
Apr 29 13:38:30.313: ISDN BR0/1/0 Q931: Sending SETUP  callref = 0x006D callID = 0x9CB8 switch = basic-net3 interface = User
Apr 29 13:38:30.313: ISDN BR0/1/0 Q931: TX -> SETUP pd = 8  callref = 0x6D
                Standard = CCITT
        Channel ID i = 0x89
                Exclusive, B1
        Redirecting Number i = 0x00008F, '9895757'
        Sending Complete
Apr 29 13:38:30.357: ISDN BR0/1/0 Q931: RX <- CALL_PROC pd = 8  callref = 0xED
        Channel ID i = 0x89
                Exclusive, B1
Apr 29 13:38:30.473: ISDN BR0/1/0 Q931: RX <- DISCONNECT pd = 8  callref = 0xED
Apr 29 13:38:30.473: ISDN BR0/1/0 Q931: TX -> RELEASE pd = 8  callref = 0x6D
Apr 29 13:38:30.497: ISDN BR0/1/0 Q931: RX <- RELEASE_COMP pd = 8  callref = 0xED
Apr 29 13:38:30.625: ISDN BR0/1/0 Q931: Applying typeplan for sw-type 0x1 is 0x1 0x1, Calling num 0504504504
Apr 29 13:38:30.625: ISDN BR0/1/0 Q931: Sending SETUP  callref = 0x006E callID = 0x9CB9 switch = basic-net3 interface = User
Apr 29 13:38:30.625: ISDN BR0/1/0 Q931: TX -> SETUP pd = 8  callref = 0x6E
                Standard = CCITT
        Channel ID i = 0x89
                Exclusive, B1
        Sending Complete
Apr 29 13:38:30.673: ISDN BR0/1/0 Q931: RX <- CALL_PROC pd = 8  callref = 0xEE
        Channel ID i = 0x89
                Exclusive, B1
Apr 29 13:38:30.789: ISDN BR0/1/0 Q931: RX <- DISCONNECT pd = 8  callref = 0xEE
Apr 29 13:38:30.789: ISDN BR0/1/0 Q931: TX -> RELEASE pd = 8  callref = 0x6E
Apr 29 13:38:30.813: ISDN BR0/1/0 Q931: RX <- RELEASE_COMP pd = 8  callref = 0xEE
Apr 29 13:38:30.837: ISDN BR0/1/1 Q931: TX -> DISCONNECT pd = 8  callref = 0xB2
Apr 29 13:38:30.857: ISDN BR0/1/1 Q931: RX <- RELEASE pd = 8  callref = 0x32
Apr 29 13:38:30.857: ISDN BR0/1/1 Q931: TX -> RELEASE_COMP pd = 8  callref = 0xB2
I configured "Redirecting Party Transformation CSS" and debug is the following. Redirect format number should be ok. Do you have any other idea?
Apr 29 15:12:04.199: ISDN BR0/1/1 Q931: RX <- SETUP pd = 8  callref = 0x44
                Standard = CCITT
        Channel ID i = 0x89
                Exclusive, B1
        Sending Complete
Apr 29 15:12:04.203: ISDN BR0/1/1 Q931: TX -> CALL_PROC pd = 8  callref = 0xC4
        Channel ID i = 0x89
                Exclusive, B1
Apr 29 15:12:04.255: ISDN BR0/1/0 Q931: Applying typeplan for sw-type 0x1 is 0x1 0x1, Calling num 0504504504
Apr 29 15:12:04.255: ISDN BR0/1/0 Q931: Sending SETUP  callref = 0x0014 callID = 0x9CDE switch = basic-net3 interface = User
Apr 29 15:12:04.255: ISDN BR0/1/0 Q931: TX -> SETUP pd = 8  callref = 0x14
                Standard = CCITT
        Channel ID i = 0x89
                Exclusive, B1
        Redirecting Number i = 0x00008F, '897897897'
        Sending Complete
Apr 29 15:12:04.299: ISDN BR0/1/0 Q931: RX <- CALL_PROC pd = 8  callref = 0x94
        Channel ID i = 0x89
                Exclusive, B1
Apr 29 15:12:04.435: ISDN BR0/1/0 Q931: RX <- DISCONNECT pd = 8  callref = 0x94
Apr 29 15:12:04.435: ISDN BR0/1/0 Q931: TX -> RELEASE pd = 8  callref = 0x14
Apr 29 15:12:04.459: ISDN BR0/1/0 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x94
Apr 29 15:12:04.531: ISDN BR0/1/0 Q931: Applying typeplan for sw-type 0x1 is 0x1 0x1, Calling num 0504504504
Apr 29 15:12:04.531: ISDN BR0/1/0 Q931: Sending SETUP  callref = 0x0015 callID = 0x9CDF switch = basic-net3 interface = User
Apr 29 15:12:04.531: ISDN BR0/1/0 Q931: TX -> SETUP pd = 8  callref = 0x15
                Standard = CCITT
        Channel ID i = 0x89
                Exclusive, B1
        Sending Complete
Apr 29 15:12:04.595: ISDN BR0/1/0 Q931: RX <- CALL_PROC pd = 8  callref = 0x95
        Channel ID i = 0x89
                Exclusive, B1
Apr 29 15:12:04.723: ISDN BR0/1/0 Q931: RX <- DISCONNECT pd = 8  callref = 0x95
Apr 29 15:12:04.723: ISDN BR0/1/0 Q931: TX -> RELEASE pd = 8  callref = 0x15
Apr 29 15:12:04.747: ISDN BR0/1/0 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x95
Apr 29 15:12:04.767: ISDN BR0/1/1 Q931: TX -> DISCONNECT pd = 8  callref = 0xC4
Apr 29 15:12:04.791: ISDN BR0/1/1 Q931: RX <- RELEASE pd = 8  callref = 0x44
Apr 29 15:12:04.791: ISDN BR0/1/1 Q931: TX -> RELEASE_COMP pd = 8  callref = 0xC4
we are still receiving the call reject from provider, so I suggest you to talk to your provider on this issue.
Ok, I will do it.
Thank you very much.
