Call forward no answer option fail CME 9.0
I have CME 9.0 with 6921 IP phones, I have a problem when I set CFNA  ( call forwar no anwer) to external number, after the timeout the call is drop.
is weird because I can set CFA to external number and CF busy to external number and both work fine but  call forward no answer
option doest not work.
the call fails when incoming call from PSTN to extension number is routed to external number  with CFNA.
when another extension call to internal extension an the routed to external nuember with CFNA , calls is success
The calls ( inco and out)  goes through a SIP trunk with local carrier.
I attach debug for this call
any sugestion??
Can you share with me the same debug from a call inside to to the internal dn that then get forwarded out successfully?
Also can you share the rest of your configuration?
Your cause codes are stating
CC_CAUSE_NO_ROUTE
The called party cannot be reached because the network that the call has been routed through does not serve the desired destination.
Have you checked this out.
http://www.cisco.com/en/US/docs/ios/voice/sip/configuration/guide/sip_cg-call_x-fer_support_TSD_Island_of_Content_Chapter.html#wp1055017
Hope any of this helps!
Hi Gregory,
Thanks for your link. The scenario was temporary and was set in the carrier's office so I can collect more information for the moment. I need o wait for the final installation..although I hope this issue does not come up.
regards
265
