Community Member
Call-Forward NOAN
I am trying to setup call-forward noan so when we go in SRST and the DID is doesn't answer we send it to a mobile
phone number. What commands do I need and or can I do that?
Community Member
Re: Call-Forward NOAN
sorry I posted config which is different scenario, i didn't realise you were asking for the no-answer scenario.
In fact it's an easy one, you can configure this under the call-manager-fallback config, using the alias command. I'll give you more specifics if you need, tomorrow.
Community Member
Is there any way to get it today by chance?
Community Member
sorry for the delay, try this:
For example your cell phone number is: 516-555-3232
Call-manager-fallback
call-forward noan 915165553232 timeout 10
Make sure you have the following dial-peer
Dial-peer voice 1010 pots
destination-pattern 91[2-9]..[2-9]......
prefix 1
port 0/1/0:23
Where 0/1/0 is your T1/E1 controller Port.
Hope this helps,if it does, please rate.
Cheers!
499
