Call forward not showing correct information
csco11063007
When I call from my IP phone to outside(mobile or any pstn number) it shows my correct DID on my mobile.But if once callforwardall assign to my mobile,and if i call my ip phone it will forward to the mobile but doesn't show the correct did of my ip phone but its showing pilot number.
ccm version 4.1
Is there any fix for this problem
Thakns in advance,
Tittu
devnetjmt
Hi Titu,
You can fix the problem changing the Calling Party Selection in Call Routing Information - Outbound Calls in Gateway web page configuration.
Use the option: Last Redirect Number (External)
The default option is Originator.
I hope it helps.
Xavier
