11-18-2011 10:25 PM - edited 03-16-2019 08:08 AM
I have serveral lines that are coming in from a PRI to my Call Manager Express (12.4(22)T / CME 7.0(1))
I need to forward all the calls that are coming in from one line to an external line. I know there is an issue doing this http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_tech_note09186a0080816cac.shtml
Right now one of the lines goes to an ephone 7100 and one goes to a voice port (fax machine). I need both lines to go back out to external lines.
I am trying to forward my line 307-922-5449 to 786-386-2221
and 307-954-3877 to 786-386-2222
How should I modify my translation rules to allow this fowarding?
Thank you for all your help
Here are my translation rules:
voice translation-rule 1
rule 2 /9723394/ /7200/
rule 3 /9543877/ /7100/
rule 4 /9229892/ /7200/
rule 5 /9549324/ /49234/
rule 6 /9549223/ /49223/
rule 7 /5778201/ /48201/
rule 12 /9225449/ /45449/
rule 15 /^.*\(....\)/ /\1/
voice translation-rule 10
rule 1 /^97233/ /33/
voice translation-rule 20
rule 1 /334./ /3079229892/
rule 5 /49234/ /3079549324/
rule 6 /49223/ /3079549223/
rule 7 /48201/ /3075778201/
rule 15 /.*/ /3079543877/
voice translation-rule 30
rule 1 /^.*\(....\)/ /\1/
voice translation-profile 1
translate called 1
voice translation-profile inTestDid
translate called 1
voice translation-profile maskswire
translate calling 20
voice translation-profile removestar
translate calling 30
voice translation-profile tp_In_DIDtoExt
translate called 1
Here is my dial peers:
dial-peer voice 9225449 pots
description Fax Machine 922-5449
translation-profile incoming tp_In_DIDtoExt
incoming called-number 9225449
direct-inward-dial
port 0/0/0:23
dial-peer voice 9543877 pots
description Inbound 9543877
translation-profile incoming inTestDid
translation-profile outgoing maskswire
translate-outgoing called 1
incoming called-number 9543877
direct-inward-dial
11-19-2011 05:40 AM
Try to use number expansion
Num expan xxx yyyyyyyyy
Hope this help
11-22-2011 12:28 PM
This is for incomming calls not for internal calls. Do I have to remove my voice translation rules for that line?
11-22-2011 02:46 PM
change it from translating to internal number to full PSTN number where you want the call to be sent out
and make sure the translated number has an outgoing pots dial peer to match and sent out to the PSTN
