call forward option
can you set the call forward option to voicemail when you are logged in with extension mobility and set it to another number when you are logged out?
1 REPLY
Re: call forward option
** Possible Resolution **
1. On the ip phone, you can select the softkey 'cfwdall'
2. You can go to CCMAdmin and on the phone configurations, you can remove/Add the call forward options if any, and click on update.
3. You can also go the CCM User page, and login as a user. Select the associated device and edit the call forward option.
Try:
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_ipphon/english/ipp7960/user/4_12/
259
