Community Member
Call Forward over sip 604
When forwarding a phone over a Cube to the pSTN, I get a 604 error.   If I call the "forwarded to:" number directly, life is good.  Is there  something under voice service voip that I am missing?
604 means doesnt exist
604 means doesnt exist anywhere. Did you make sure the forwarded number doesnt have any leading 9 or 8 (outside access codes)?
Please rate useful posts.
Community Member
If i dial the number, life is
If i dial the number, life is good, and the outside access code is stripped out.  Would not the forwarded number also match the same dial peer, since its the same format?
Difficult to comment on that,
Difficult to comment on that, can you post some debugs here? debug ccsip message/debug voip ccapi inout from the CUBE would be great.
Community Member
Hello George.  I got it
Hello George.  I got it sorted.   There were 2 diversion headers in the invite, the first coming from cucm, the 2nd from the sip profiles.  The first was invalid, so its why it was failing.  I unchecked "redirect diversion header-outbound" on the sip trunk, reset, and all is working.  Correct diversion headers.
Thank you for your quick reply and suggestions.
79
