Call Forward problems.
I am suddenly having issues forward calls.  I am able to dial the internal ext fine but when I attempt a call forward all to the number...I receive a call cannot be completed as dialed as soon as the second digit of the extension is entered.
1 ACCEPTED SOLUTION
Hi Jim.
Assuming you are running CUCM
Have you looked into CFWA CSS in line configuration page?.
If yes, use Route plan report or DNA to verify if that CSS is able to reach the desired destination.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
1 REPLY
Hi Jim.
Carlo
123
