Call forward redirect number passing 4 digits instead of 7
I am forwarding my ip phone to a cell number. When the call is made to the ip phone and in turn forwarded to the cell phone, the redirect number is only 4 digits so my telco regects the number as incomplete. How do I adjust this to output 7 or 10 digits for the redirecting number. I am using CCM 4.02 with a 2811 with c2800nm-ipvoicek9-mz.124-13a.bin. Here is a debug of the output...
Mar 23 13:57:46.860 mdt: ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8 callref = 0x063B
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Progress Ind i = 0x8083 - Origination address is non-ISDN
Calling Party Number i = 0x0181, '2814801453'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x80, '18322280597'
Plan:Unknown, Type:Unknown
Redirecting Number i = 0x00008F, '5696'
Mar 23 13:57:46.908 mdt: ISDN Se0/0/0:23 Q931: RX <- STATUS pd = 8 callref = 0x863B
Cause i = 0x80E428 - Invalid information element contents
Call State i = 0x01
Mar 23 13:57:46.956 mdt: ISDN Se0/0/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x863B
Mar 23 13:57:47.656 mdt: ISDN Se0/0/0:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x863B
Cause i = 0x829C - Invalid number format (incomplete number)
Bronze
Re: Call forward redirect number passing 4 digits instead of 7
Have you checked your translation patterns and masks? It has to be getting converted to 4 digits by a translation patter or mask.
Yes I have checked both. I only have one translation and that is for the operator. The mask has the full 10 digit number.
Bronze
Here is the order of applied number transformations:
1. External phone number mask
2. Translation pattern
3. Route pattern
4. Route list using route group details
5. Transformation on the terminating device
Make sure you check the mask in all of those places.
You need to check the following:
1- Gateway Page where you registered your 2811
2- Outbound Calls - Calling Party Selection
Check it to be the First Originating Number instead of the current status,
Please rate or tell me if it works or not.
Thank you
Bassam
It turns out you don't need the redirect number in there at all. To turn it off go to the Gateway cinfig and uncheck the following Redirecting Number IE Delivery - Outbound. I did have to restart my CCM service before the change took effect for some reason.
614
