Call Forward to mobile unallocated/unassigned
Hey,
I am having issue with a customer. I have tried all possiblities. Manimpulating translation rules and tried the below link
http://www.cisco.com/en/US/tech/tk801/tk133/technologies_tech_note09186a00800b48cb.shtml
but nothing worked.
Please find below the debug
Oct 18 09:20:46.976: ISDN BR0/0/1 Q931: RX <- RELEASE pd = 8  callref = 0x62
Oct 18 09:20:46.980: ISDN BR0/0/1 Q931: TX -> RELEASE_COMP pd = 8  callref = 0xE2
Oct 18 09:20:47.244: ISDN BR0/0/1 Q931: TX -> RELEASE pd = 8  callref = 0x69
Oct 18 09:20:47.344: ISDN BR0/0/1 Q931: RX <- RELEASE_COMP pd = 8  callref = 0xE9
Oct 18 09:20:49.940: ISDN BR0/0/1 Q931: RX <- SETUP pd = 8  callref = 0x63
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x82
Preferred, B2
Calling Party Number i = 0x1183, '447720742215'
Plan:ISDN, Type:International
Called Party Number i = 0xA1, '263793780'
Plan:ISDN, Type:National
Sending Complete
Oct 18 09:20:49.944: //-1/69BE0066807A/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x2228E2C0, Call Info(
   Calling Number=447720742215,(Calling Name=)(TON=International, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=263793780(TON=National, NPI=ISDN),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=1, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=bri, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Oct 18 09:20:49.948: ISDN BR0/0/0 Q931: Applying typeplan for sw-type 0x1 is 0x1 0x1, Calling num 00447720742215
Oct 18 09:20:49.948: ISDN BR0/0/0 Q931: Sending SETUP  callref = 0x006A callID = 0x806C switch = basic-net3 interface = User
Oct 18 09:20:49.948: ISDN BR0/0/1 Q931: TX -> CALL_PROC pd = 8  callref = 0xE3
Channel ID i = 0x8A
Exclusive, B2
Oct 18 09:20:49.952: ISDN BR0/0/0 Q931: TX -> SETUP pd = 8  callref = 0x6A
Standard = CCITT
Channel ID i = 0x89
Exclusive, B1
Calling Party Number i = 0x1183, '00447720742215'
Called Party Number i = 0xA1, '3409870403'
Sending Complete
Oct 18 09:20:50.232: ISDN BR0/0/0 Q931: RX <- CALL_PROC pd = 8  callref = 0xEA
Channel ID i = 0x89
Exclusive, B1
Oct 18 09:20:50.332: ISDN BR0/0/0 Q931: RX <- DISCONNECT pd = 8  callref = 0xEA
Cause i = 0x8281 - Unallocated/unassigned number
Progress Ind i = 0x8288 - In-band info or appropriate now available
Oct 18 09:20:50.336: ISDN BR0/0/1 Q931: TX -> DISCONNECT pd = 8  callref = 0xE3
Cause i = 0x8081 - Unallocated/unassigned number
Oct 18 09:20:50.456: ISDN BR0/0/1 Q931: RX <- RELEASE pd = 8  callref = 0x63
Oct 18 09:20:50.456: ISDN BR0/0/1 Q931: TX -> RELEASE_COMP pd = 8  callref = 0xE3
Oct 18 09:20:50.460: ISDN BR0/0/0 Q931: TX -> RELEASE pd = 8  callref = 0x6A
Oct 18 09:20:50.568: ISDN BR0/0/0 Q931: RX <- RELEASE_COMP pd = 8  callref = 0xEA
-ITALY#u all
All possible debugging has been turned off
-ITALY#term no mon
-ITALY#e   config
Configuring from terminal, memory, or network [terminal]?
Could some one please shine some light on this issue
Please rate the post
Shibly Ibrahim
Please rate the post Shibly Ibrahim
Everyone's tags (4)
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
That dis not a cellphone number and you posted no trace.
To set plan / type use "isdn map ." command, not translation rule.
Hall of Fame Super Silver
Re: Call Forward to mobile unallocated/unassigned
Are you making international call?
If so you are missing intl prefix I.e. 00.
Can you post your config?
Chris
Hey,
No its a mobile number locally. I called from the UK. Its italy and they dial mobile numbers without 0 beginnign with 3
Shibly Ibrahim
Shibly Ibrahim
What if you massage your caller ID to a local Italian number?
I tried translation-rule
rule 1 // /0263793780/
doesnt work i am not sure whats wrong
Shibly Ibrahim
For outgoign calls, set type/plan to unknow/unknown
Hey Paolo,
Tried doesnt work
rule 2 // /0263793780/ type unknown unknown plan any isdn
Shibly Ibrahim
Call is being release from remote end.
Ask the remote end regarding there expectaiton for this called number and calling number digit and it's plan and type.
Try calling that mobile number directly from your side and check if its working?
Nishant Savalia
Regards, Nishant Savalia
Hey Nishant,
calling directly it works fine.
Shibly Ibrahim
What plan and type you are sending while dialing directly? Is it the same of forwarded call?
Then please co-ordinate with remote party regarding disconnecting the forwarded call.
Nishant Savalia
1406
