Community Member
Call Forward unregistered issue when Extension mobility user logout
Call Mangerer 7.0
Unity 5.0
voice gateway 2811ISR with IOS:
c2800nm-spservicesk9-mz.124-11.T3.bin
MGCP gateway connected to MD110 PABX via QSIG trunk.
User Device Profile DN1 6288, configured Call Forward unregistered to voicemail.
When Extension mobility user logout, incoming call from PABX/PSTN to DN6288 get connected to voicemail for about 5 secs and then dropped.
If we change the Call Forward unregistered to another IP phone, that worked fine.
If we close a IP Communicator with Call Forward unregistered to voicemail configured, that worked fine.
Here is the debug isdn q931 from voice gateway:
Jun 15 15:39:44 AEST: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0524
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA1838F
Preferred, Channel 15
Facility i = 0x9FAA068001008201008B0100A1100201010201553008820301B850860101
Facility i = 0x9FAA068001008201008B0100A11002010202010080084120526F6A617320
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0181, '22225908'
Plan:ISDN, Type:Unknown
Called Party Number i = 0xC9, '6288'
Plan:Private, Type:Subscriber(local)
User-User i = 0x00FE, 'U', 0x0100, 'Y', 0x0100B10C06, 'I', 0x81, '5908', 0x0F0A818780, 'A Rojas'
Shift to Codeset 4
Codeset 4 IE 0x31 i = 0x81
Jun 15 15:39:44 AEST: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x8524
Channel ID i = 0xA9838F
Exclusive, Channel 15
Jun 15 15:39:44 AEST: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8 callref = 0x8524
Facility i = 0x9FAA06800100820100A1080201010201018400
Progress Ind i = 0x8088 - In-band info or appropriate now available
Jun 15 15:39:44 AEST: ISDN Se0/0/0:15 Q931: TX -> FACILITY pd = 8 callref = 0x8524
Facility i = 0x9FAA068001008201008B0100A114020101020114300C0A01030A0102800436313939
Jun 15 15:39:45 AEST: ISDN Se0/0/0:15 Q931: TX -> CONNECT pd = 8 callref = 0x8524
Facility i = 0x9FAA068001008201008B0100A11802010102011630100101FFA00B8009566F6963656D61696C
Facility i = 0x9FAA06800100820100A1110201020201028009566F6963656D61696C
Connected Number i = 0x0081, '6199'
Jun 15 15:39:45 AEST: ISDN Se0/0/0:15 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x0524
Jun 15 15:39:50 AEST: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x0524
Cause i = 0x8190 - Normal call clearing
Jun 15 15:39:50 AEST: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x8524
Jun 15 15:39:50 AEST: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x0524
Jun 15 15:39:53 AEST: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x81B9
Jun 15 15:39:53 AEST: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x01B9
Jun 15 15:39:53 AEST: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x81B9
Appreciate any help.
1 REPLY
Community Member
Re: Call Forward unregistered issue when Extension mobility user
Anyone seen this issue before?
718
