Call Forward using a code
Standard users are configured with the ability to call forward to internal extension only.
Certain users will have the ability to forwrad calls to there mobiles.
To invoke the call forward the users will be given a code e.g #1234, this needs to translate to there mobile number.
This will be for a very limited set of users.
What is the best way to do this on CUCM 6.1?, can I use client matter codes.
1 REPLY
Re: Call Forward using a code
CMC and FAC require someone to dial them, so no good to CFA.
you can limit this with a translation pattern for #1234 and only those users can reach the partition were you configured it
java
if this helps, please rate
java
www.cisco.com/go/pdi
164
