09-15-2010 05:17 AM - edited 03-16-2019 12:47 AM
Hi all,
I have cme 7.1 i configured call-forward all & its working fine for internal & external users.
Problem : lets suppose i enable call forward all on extension A ( having extension 836) to my mobile, when any body from PSTN calls to Extension A the call is forwarding to my mobile but instead of getting my DID ( 17383836 ) on my mobile i m getting the Main Number of PRI on mobile ( 17383838 ).
Troubleshooting: I enabled debug isdn q931 & i saw that when i call to extension A ( which has call-forward all enable ) its calling party number shows me 1738333381821( 33381821 is the callers mobile number from PSTN ) .
As per my PRI provider they said for getting the correct DID on mobile you need to send me only eight digits along with extension.
Below is the debug isdn q931 & config of my translation rules:
BIPA-CCME#
Sep 15 15:14:51.314: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x38DE
Sending Complete
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA18386
Preferred, Channel 6
Progress Ind i = 0x8281 - Call not end-to-end ISDN, may have in-band inf
o
Calling Party Number i = 0x2183, '33381821'
Plan:ISDN, Type:National
Called Party Number i = 0xC1, '17383836'
Plan:ISDN, Type:Subscriber(local)
Sep 15 15:14:51.314: ISDN Se0/0/0:15 Q931: Received SETUP callref = 0xB8DE call
ID = 0x037F switch = primary-net5 interface = User
Sep 15 15:14:51.330: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0xB
8DE
Channel ID i = 0xA98386
Exclusive, Channel 6
Sep 15 15:14:51.338: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is
0x2 0x1, Calling num 1738333381821
Sep 15 15:14:51.338: ISDN Se0/0/0:15 Q931: Sending SETUP callref = 0x056C callI
D = 0x84ED switch = primary-net5 interface = User
Sep 15 15:14:51.342: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x056C
Sending Complete
Standard = CCITT
Channel ID i = 0xA9838A
Exclusive, Channel 10
o
Calling Party Number i = 0x2183, '1738333381821'
Called Party Number i = 0xC1, '39583729'
Sep 15 15:14:51.398: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x8
56C
Sep 15 15:14:55.030: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8 callref = 0x85
6C
Progress Ind i = 0x8288 - In-band info or appropriate now available
Sep 15 15:14:55.038: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8 callref = 0xB8
DE
Sep 15 15:14:58.378: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x
38DE
Cause i = 0x8290 - Normal call clearing
Sep 15 15:14:58.382: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8 callref = 0xB8D
E
Sep 15 15:14:58.386: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x
056C
Cause i = 0x8090 - Normal call clearing
Sep 15 15:14:58.490: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref =
0x38DE
Sep 15 15:14:58.518: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x856
C
Sep 15 15:14:58.518: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref =
0x056C
BIPA-CCME#
BIPA-CCME#
voice translation-rule 1
rule 1 /^17383\(...\)/ /\1/
voice translation-rule 2
rule 1 // /17383/
voice translation-profile PSTNIN
translate called 1
voice translation-profile PSTNOUT
translate calling 2
if i call from my extension to the mobile its showing me correct DID im facing this problem only in call forward all.
Can any body tell me what translation shoud i configure which works only for call forward all + replace the 33381821 (from 1738333381821) with the correct extension.
09-19-2010 05:50 AM
Hi all,
does any body has solution for the following problem ??
09-20-2010 08:02 AM
This profile is prefixing the digits which the provider is complaining abourt:
translate calling 2
Why is that on there to begin with? If you remove PSTNOUT from the outbound POTS peer, does it fix the issue?
