call forward
I have the CME 3.3 with 7902 phones and I'm trying to do call-forward when extension 100 is busy to 101.
This is the configuration:
telephony-service
max-ephones 5
max-dn 5
ip source-address 192.168.3.1 port 2000
auto assign 1 to 5
user-locale ES
network-locale ES
create cnf-files version-stamp Jan 01 2002 00:00:00
max-conferences 4 gain -6
transfer-system full-consult
directory entry 45 667433712 name Santi
directory entry 4 101 name pruebas
directory entry 20 667433712 name santi
ephone-dn 1 dual-line
number 100 no-reg primary
call-forward busy 101
call-forward noan 101 timeout 10
ephone-dn 2 dual-line
number 101 no-reg primary
ephone-dn 3 dual-line
number 102 no-reg primary
But doesn't runs neither call-forward busy and noan
when the extension 100 is busy, if you call you hear normal dial tone, but never is transfered.
Any ideas?
Hall of Fame Super Gold
Re: call forward
Hi Sarenos,
your ephone-dn have dual-line, so they will automatically have call waiting when a second call comes in. Probably you do not the second call because the 7902 have no display. Either configure the ephone-dn without dual-line, or with 'huntstop channel'.
Also, you can configure names, labels etc directly under the ephone-dn without using 'directory entry'.
Hall of Fame Super Red
Re: call forward
Hi Santi,
Just to add a note Paolo's good info (also posted on End user Thread.)
Because this DN is set up as dual-line you need to add the following. Have a look;
The following example creates an ephone-dn with the number 1001 in dual-line mode. The no huntstop command allows calls to continue to hunt to other ephone-dns if this one is busy or does not answer. The huntstop channel command disables call hunting to the second channel of this ephone-dn if the first channel is busy or does not answer.
Router(config)# ephone-dn 10 dual-line
Router(config-ephone-dn)# number 1001
Router(config-ephone-dn)# no huntstop
Router(config-ephone-dn)# huntstop channel
Router(config-ephone-dn)# exit
From this CME doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_command_reference_chapter09186a0080611350.html#wp1056194
Hope this helps!
Rob
Re: call forward
Actually I'm a bit puzzled by the fact that one needs 'huntstop channel' to forward on no answer. Logic would suggest that if a call is not answered on the first channel, no much more chances are that it will be on the second. But perhaps there are reasons not immediately understood for this.
Re: call forward
As Rob mentioned, dual-line ephone-dn's support call waiting.
An incoming call will attempt to hit the first channel of the ephone-dn. If that channel is busy (because the user is on a call) then the call will immediately hunt to the second channel, at which point the user will see the second incoming call on their display (assuming the phone has one) and will hear call-waiting beeps.
'huntstop channel' disables this behaviour.
Re: call forward
I have tried the no huntstop but it continues failing, when you try to call to extension 100 and it's busy now you can hear busy tone instead of dial tone as before.
The call-forward to 101 still it's not running. What I'm doing wrong?
Any ideas? thanks a lot
Re: call forward
This is the configuration now
telephony-service
max-ephones 5
max-dn 5
auto assign 1 to 5
user-locale ES
network-locale ES
huntstop channel
no huntstop
ephone-dn 4 dual-line
ephone-dn 5 dual-line
number 964812539
ephone 1
mac-address 0013.60C3.CE02
type 7902
button 1:1
ephone 2
mac-address 0012.431E.BF3E
type 7902
button 1:2
Re: call forward
try this:
telephony-service
transfer-pattern .T
129
