call forwarded from turret phone, not working.
Abhishek Singh
We have an issue at one of our locations .
Whenever there is call being forwarded to an outside cell  phone number from turret phone at one of our location  it doesn’t work. (for caller) Call  disconnect after almost 1 minutes of Silence. (For final called pary) his phone  rings for just  second and disconnect and process repeats and lasts about 1  minute.
As per gateway debugs, we  see a setup being  received.
040944: *Dec 15  22:10:53.114 UTC: ISDN Se0/0/0:23 Q931: RX <- SETUP pd = 8  callref = 0x0F4A
Bearer  Capability i = 0x8090A2
Standard  = CCITT
Transfer  Capability = Speech
Transfer  Mode = Circuit
Transfer  Rate = 64 kbit/s
Channel ID i =  0xA98381
Exclusive, Channel 1
Facility i =  0x9F8B0100A10F02013006072A8648CE1500040A0100
Protocol  Profile =  Networking Extensions
0xA10F02013006072A8648CE1500040A0100
Component  = Invoke component
Invoke Id = 48
Operation = InformationFollowing (calling_name)
Name information in subsequent FACILITY message
Progress Ind i  = 0x8283 - Origination address is non-ISDN
Calling Party  Number i = 0x2183, '214xxxxx51'
Plan:ISDN, Type:National
Called Party  Number i = 0x80, '3052'
Plan:Unknown, Type:Unknown
Then CM sends call setup to turret through another  gateway.
040356: .Dec 15  22:17:05.507 UTC: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8  callref = 0x03AE
Sending  Complete
Bearer  Capability i = 0x8090A3
Standard  = CCITT
Channel ID i =  0xA9839F
Exclusive, Channel 31
Facility i =  0x9FAA06800100820100A1080201000201008400
Same gatway then receives setup back for the forwarded call  (hairpin)
040947: *Dec 15  22:10:53.718 UTC: ISDN Se0/1/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0694
Sending  Complete
Standard  = CCITT
Channel ID i =  0xA98396
Exclusive, Channel 22
Facility i =  0x9FAA06800100820100A119020209D402011530100201010A0101A108A006800433303532
Calling Party  Number i = 0x0083, '21xxxxxx51'
Called Party  Number i = 0x80, '91.......388'
Call manager  then forwards the call to telco
040949: *Dec 15  22:10:53.838 UTC: ISDN Se0/0/1:23 Q931: TX -> SETUP pd = 8  callref = 0x050F
Standard  = CCITT
Channel ID i =  0xA98397
Exclusive, Channel 23
Calling Party  Number i = 0x2183, '21......51'
Called Party  Number i = 0xA1, '171........88'
040950: *Dec 15  22:10:53.902 UTC: ISDN Se0/0/1:23 Q931: RX <- CALL_PROC pd = 8  callref =  0x850F
For which we  receive a progress ind from telco.
040951: *Dec 15  22:10:56.478 UTC: ISDN Se0/0/1:23 Q931: RX <- PROGRESS pd = 8  callref =  0x850F
Progress Ind i  = 0x8288 - In-band info or appropriate now available
We receive no  message for next 10 seconds.
After 10  seconds the call originating telco disconnects the call.
040953: *Dec 15  22:11:03.306 UTC: ISDN Se0/0/0:23 Q931: RX <- DISCONNECT pd = 8  callref =  0x0F4A
Cause i =  0x80E6 - Recovery on timer expiry
collected traces for successful call hoever in that call telco doesn’t send call  proc in response to set. It  sends alerting.
In both good  and bad call case call is going out through same circuit. That is 0/0/1  of srst  gateway of the location.
Can somebody guide on this.
Whatever level you reach getting better never stops -- Sachin Tendulkar
Mike Lydick
Are these H323 dialpeers. Have you adjusted the H225 call setup timers? Also have you adjusted callmanager to allow for additional call connect time? Seems from the call you are transverse a few gateways and the call connect is timing out.
The T310 Timer sets how long to wait to get a response such as ALERTING or CONNECT to  a Call Proceeding message.
http://www.cisco.com/en/US/tech/tk1077/technologies_tech_note09186a0080094487.shtml
Cause i =  0x80E6 indicates timeout on a longdistance call. Looks like the carrier is looking for a connect mesg and does not recieve so it times out.
Mike
carrier sends a calls progressing note.. can attach the deubgs if u want.
