Call Forwarding a call with CCM 6.0
When you press the CFWDALL button and begin to enter an extension you get a message that says, " Your call can not be completed as dialed"
What changes do I make in CCM 6.0 to allow users to forward calls?
1 REPLY
Re: Call Forwarding a call with CCM 6.0
Ensure that you have configure a valid Calling Search Space on the Line appearance CFA setting.
Specify a CSS which provides the appropriate dialing permissions for which the user is able to call forward such as Internal, Local, Mobile etc.
Allan.
Pls rate this post if you find it helps.
108
