Call Forwarding / Displayed Number on Forwarding target with H.323 Gateway
Hi Community,
i´m wondering if there is sort of a simple way to get this working properly.
Scenario:
Germany, variable dial plan, no fixed NANP, and we have ClipNoScreening ;)
We use 0 for getting PSTN-dialing.
We have internal DNs, for example a 6789, 4 Digits. We use external phone number mask on our lines, 123456XXX
Our main number is 0123/456-xxx
When i call outside everything is displayed fine on the called target, +49 123/456789.
When i forward a call on my cellphone, with CFA target of 00111/222333444 (my cellphone example), and an internal colleague from within our office, is calling my office phone, everything is ALSO displayed fine.
Now here comes the BUT:
When someone calls from PSTN on my office-phone, i get displayed on my cellphone the +49 (0) 0xxxxxxxx, which means the caller number PLUS the added 0 from the gateway. Which is completely consequent and correct, since we add them on the gateway, when a call comes in, to be able to just answer directly on the office phone.
The rule on the H323 gateway:
voice translation-profile OUTGOING-VOIP
 translate calling 1
 translate called 2
voice translation-rule 1
 rule 1 /^\(.*\)/ /0\1/ type subscriber unknown plan any unknown
 rule 2 /^\(.*\)/ /00\1/ type national unknown plan any unknown
 rule 3 /^\(.*\)/ /000\1/ type international unknown plan any unknown
voice translation-rule 2
 rule 6 /4560$/ /6600/
 rule 9 /^456\(...\)$/ /6\1/
voice translation-profile OUTGOING-POTS
 translate calling 3
 translate called 4
voice translation-rule 3
 rule 1 /^00049/ /0/ type unknown national
 rule 2 /^0/ // type unknown subscriber
 rule 3 /^00/ /0/ type unknown national
 rule 4 /^000/ /00/ type unknown international
voice translation-rule 4
 rule 2 /^00049\(.*$\)/ /\1/ type unknown national
 rule 3 /^000\(.*$\)/ /\1/ type unknown international
 rule 4 /^00\(.*$\)/ /\1/ type unknown national
 rule 5 /^0\(.*$\)/ /\1/ type unknown subscriber
dial-peer voice 10456 voip
 translation-profile outgoing OUTGOING-VOIP
 destination-pattern 456.T
 progress_ind setup enable 3
 modem passthrough nse codec g711ulaw
 session target ipv4:<IP-OF-CUCM>
 incoming called-number .
 voice-class codec 1
 voice-class h323 1
 dtmf-relay h245-alphanumeric
 fax-relay ecm disable
 fax rate disable
 fax protocol pass-through g711ulaw
 no vad
 no supplementary-service h225-notify cid-update
dial-peer voice 345000 pots
 tone ringback alert-no-PI
 translation-profile outgoing OUTGOING-POTS
 destination-pattern 0.T
 progress_ind alert enable 8
 progress_ind progress enable 8
 progress_ind connect enable 8
 port 0/0/0:15
 forward-digits all
In case of forwarding the external call to an external device, like for example a cellphone, this is crap.
Its obvious regarding the debugs all is working as designed ;), because my phone just forwards the full calling number including the added 0, since i put in to forward the originating calling DN.
My question now:
Can i simply correct this behavior somehow, also for international calls which would the 00 get added by the gateway?
Many thanks in advance for some input,
Andreas
78
