Call Forwarding issue when it is done from the CUCM admin
sienz.sienz
I just found out that we have Call Forwarding issue with our CUCM. I can not call forward the phone from the CUCM admin.
After i setup the call forwarding in the CUCM, the phone changes and re-registered, then the phone screen is showing that the phone is forwarded to the forwarded number.
but when i call it, it is still ring to the phone, then to voicemail as the phone is not forwarded.
But when i forwarded from the desk phone, It works and i can see the number is filled in the CUCM admin page (Destination).
Any inputs?
gogasca
Level 10
Level 10
this seems to be a change notification problem.
which version of cucm you are using?
this iwll tell us how to troubleshoot since architecture is different among all versions for this process.
Sorry, i forgot to mention the CUCM version.
We have CUCM System version: 6.1.1.2000-3
gogasa,
Just want to add, the changes was happen on the phone when i do it from CUCM admin. I see the phone is changed and in the call forwarding status and showing the call forwarded number but it is only showing on the screen.
the actual phone is not forwarded. It rings to the phone when I call.
Hi Sienz,
Maybe you are hitting this bug;
CSCsf03226 Bug Details
Cnf doesn't work when call forwarding setting updated on DN page
Symptom:
Change notify does not occur when call forwarding settings are updated on the DN page
Conditions:
CM 6.0.0.9801-148
Workaround:
Restart CCM
Further Problem Description:
Dialing DN intermittently gets reorder tone after updating call forwarding settings on the DN page Status
Fixed
Severity
2 - severe
Last Modified
Any Time
Product
Cisco Unified Communications Manager (CallManager)
Technology
1st Found-In
6.0(0.9801.148)
Fixed-In
Release-Pending
Hope this helps!
Rob
