Community Member
CALL FORWARDING NOT WORKING
I have configured Client matter code in local outgoing partition. Now if I going to use call forwarding for any ext it's not working. Example I have ext. 9121 and I have done call forwarding to my mobile number but it's not working. I think client matter code is activated that is the reason behind it. But my question: is there any way to use call forwarding simultaneously with Client matter code?
please guide...
1 REPLY
Re: CALL FORWARDING NOT WORKING
u could make a trik
for example lets say ur outgoing calls with Client matter code on the route pattren is
9.XXXXXX
and u have discard pre dot
make another route pattren and make it without Client matter code
for example
8.XXXXXX
also put discard pre dot in the called number transformation in the route pattren setting page
and in thecall forward put the one start with 8
good luck
if helpful Rate
307
