Call Forwarding of Shared Line Scenario....
Hi guys…
Is there any way that anyone can think of to provide the ability to call forward a shared line on a handset without using the CM User page?
I.e. 7942 with Line 1 as their personal line and the line 2 as shared line. At present, pressing the call forward only selects line 1 with no option to choose the second line (which is the shared line they want to forward).
Any suggestions greatly appreciated!
Cheers!
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Hi James,
I believe Bruno may be referring to CME where the Call Forward of secondary
lines is possible (+5 Bruno )
But for CUCM as you have discovered, you can only Call Forward "Primary" Lines (Line 1) via
the IP phones. This is covered in the following Bug/Enhancement;
CSCdr03425 - AVVID: Allow additional line appearances to be forwarded from phone
Description
A user cannot not forward non-primary line appearances from the phone
Details
First Found in:                          (9)
2.3(1),3.0(7),2.4(2b),4.2,3.1(3a)
3.3,7.1(2),5.1,6.1(3)
Status:
Open
Last Modified:
Apr 17,2012
Product:
Cisco Unified Communications Manager (CallManager)
Platform:
Dependent
Severity:
6 - enhancement
There is a third party product that will do what you want
IPPhone callForwarder
This   new version brings to the user the ability of defining and setting the   call forwards from the IP Phone. When selecting the IP Phone   callForwarder service, a menu with all available lines will appear.   After selecting the line the user wishes to set the forward on, a new   menu containing the forward definitions will show on screen. Only those   forwarding parameters definied by the Administrator will be displayed.   These parameters will show the actual forward destination. The user  can  then set any of these callForwards.
From this good link;
http://www.myvoipsource.org/open-source-tools/ip-phone-callforwarder/
Or you can Call Forward via ccmuser or ccmadmin
Cheers!
Rob
"Always movin' ahead and never lookin' back" - Springsteen
Re: Call Forwarding of Shared Line Scenario....
One way is you press the Button for second/Shared Line on the phone and put th CFwd.
Ensure that you Phone have the proper softkey template (seized) assigned to your Phone
Cheers Bruno Rangel Please remember to rate helpful responses using the stars bellow and identify helpful or correct answers .
Sorry, what do you mean by putting "seized" in brackets?
Basically when picking up the 2nd line, the "CFwdALL" automatically gets greyed out....
Hi James,
Description
Details
First Found in:                          (9)
Status:
Open
Last Modified:
Apr 17,2012
Product:
Platform:
Dependent
Severity:
6 - enhancement
Cheers!
Rob
Yes Rob
Good approach (plus five Rob).
Yes, +5 for both you guys !!!
Your help much appreciated!
2350
