Call forwarding on CallManager
All,
I have a CallManager at NYC and another one at Dublin. The two offices can all each other through IP WAN.
Can I configure the NYC CallManager so that if anyone called a NYC number, it will ring a Dublin phone?
1 REPLY
Re: Call forwarding on CallManager
Yes, use a call forward option from a phone or configure a translation pattern.
I'm assuming this is clustering over the WAN as you don't mention anything about an ICT.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
156
