Call Forwarding on Cisco Phone
We have CCM 6.X cluster and have 7960/7961 IP phones with 5 lines/buutons configured. I want to do a "Call Forward All" for the 5th line on the phone to a different number/extension. How can I achieve this directly through the phone.
I am aware that I can achieve this for the first line/button using "CFwdALL" softkey on the phone.But when I try for 5th button it gives error "That key is not active here".
I am also aware that this can be achieved by login to the phone through web using a ccm user id and configure a call forward all for the required line. But wanted to know if this can be achieved directly through the phone .
KMS
1 REPLY
Re: Call Forwarding on Cisco Phone
that is WAD, CFA is only for primary line
use this
IP-Phone Callforwarder
http://www.myvoipsource.org/tools/ip-phone-callforwarder/
please use the search function on NetPro, this is a very common question and there are lots of previous posts on the subject
java
if this helps, please rate
java
www.cisco.com/go/pdi
1285
