call forwarding problem
hi! recently i have an issue with our call forwarding in cisco call manager. It can forward the call successfully, but the caller id was not displayed in the forwarded number (external mobile number). Instead of displaying the caller id, the ISDN main line was displayed. It works fine when the caller is an internal number I see the issue when the caller is an external number.
I checked the gateway, i can see the orignial caller id, and called number. I can also see the orignial caller id with the forwarded number there.
What should i check and how should i trouble shoot the issue?
Thanks.
1 ACCEPTED SOLUTION
You should check on the trunk if SIP or on the PRI and ensure the Calling Party Selection on outbound calls or set to First Redirect Number (External) and test.
Also if you can attach some debugs from the voice gateway that would be great to determine if the issue is with the telco or the Call Manager
Hi dave,
Which gateway you are using?
Nishant Savalia
Regards, Nishant Savalia
hi! it;s a cisco gateway.
Most likely there's nothing to troubleshoot here, in many cases the telco won't allow you to send anything beyond the DID range you own as calling party and will overwrite it with the main/billing DID if you do so.
If you see the right info when debugging the call on the GW, but still get nothing but the main DID when the calling party does not belong to your range, then you need to call telco and see if they can change that.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
hi! This was working all the while. Only recently that the issue occured. So, i don't think the issue is from the telco.
Here's the log i see when i turn the isdn debug. i guessed it's showing the correct info. Just that the forwarded receiver is not seeing the Original caller id, but the main line number instead. Thanks.
Feb  6 14:49:49.617: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0576
        Sending Complete
        Bearer Capability i = 0x9090A3
                Standard = CCITT
                Transfer Capability = 3.1kHz Audio
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA1839A
                Preferred, Channel 26
        Progress Ind i = 0x8283 - Origination address is non-ISDN
        Calling Party Number i = 0x4183, '78844515' <--------------------------Original Caller ID
                Plan:ISDN, Type:Subscriber(local)
        Called Party Number i = 0x80, '68814433' <-------------------------------Called number
                Plan:Unknown, Type:Unknown
Feb  6 14:49:49.669: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x8576
        Channel ID i = 0xA9839A
                Exclusive, Channel 26
Feb  6 14:49:49.669: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x1217
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Calling Party Number i = 0x4183, '78844515' <------------------------------Original Caller ID
        Called Party Number i = 0x80, '91202222' <-----------------------------------Forwarded number
Feb  6 14:49:49.725: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x9217
Feb  6 14:49:54.425: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x9217
        Progress Ind i = 0x8288 - In-band info or appropriate now available
Feb  6 14:49:54.429: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8  callref = 0x8576
Feb  6 14:50:01.773: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x0576
        Cause i = 0x829000000000 - Normal call clearing
Feb  6 14:50:01.789: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x1217
        Cause i = 0x8290 - Normal call clearing
Feb  6 14:50:01.821: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x8576
Feb  6 14:50:01.933: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x9217
Feb  6 14:50:01.937: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x0576
Feb  6 14:50:01.973: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x1217Feb  6 14:49:49.617:
The last point over which you have control of this, is that SETUP message, if the information for the call is what you expect in that message, then that's all you can do. If the called party doesn't receive the same info, it's not something you can fix, someone in the middle is doing that, and that someone in the middle, is your telco, and depending on the call flow, maybe other telcos.
java
java
hi! sorry, the issue hsa not been resolved. I accidentally clicked on the correct answer.
what should i check on the outbound calls portion? Currently it's set as originator. It has been working with this setting.
what debug mode should i use to troubleshoot this issue? and what shd i lookout for?
Hi dave,
From the debug it is clear that the forwarded number is sent out of your PRI i.e. towards Telco. Am i right?
Please try below command under s0/0/0:15
int s0/0/0:15
isdn outgoing ie redirecting-number
exit
Nishant Savalia
216
