Call forwarding related issues in UCM
I have a cucm ver 8.6 cluster with two locations. location 1 uses 5xxx and location 2 uses 6xxx extensions. Both location has their own h.323 gateways for PSTN calls and WAN link for intersite calls. Somebody in location 2 setup the call forwarding to his/her home phone number which is a local number to location 2. Now, when somebody from location 2 calls his/her extension, call gets forwarded to the forwarded number without any problem. However, when someobdy from location 1 calls the same extension in location 2, the user is prompted to prefix 1 saying it is a long distance call. Does anybody out there have idea why that happens?
Thanks, Badri
3 ACCEPTED SOLUTIONS
VIP Super Bronze
Re:Call forwarding related issues in UCM
This is a documented issue with local route groups. What is happening is that cucm is using the gateway of the calling device and not that of the forwarding device.
To resolve this..
1. You can set all call forward to use the full dialling pattern, so that no matter which gateway attempt to make the call, it will work
2. Reconfigure your cucm not to use LRG and just create seperate pattern for each location
3. Upgrade to cucm 9.x, where this issue is resolved
Sent from Cisco Technical Support Android App
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
VIP Super Bronze
This is not TEHO related and they are two different things. Most likely in TEHO you have defined a differrent route pattern that routes the call to the remote location. However for Call forwarding on LRG, the issue is that the gateway used for the call is the caller gateway not the called user gateway, hence the call fails because the exchange of the called user requires a prefix 1.
My string recommendation is to avoid LRG until you can upgrade to 9.X..
Its a difficult one because you cant use voice translation rule since you cant identify the patterns that need prefixing 1 without affecting local calls on the gateway
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Hall of Fame Super Red
Hi Badri,
One thing to add to the awesome info from my friend Deji (+5 "D")!
The release of CUCM 9.x adds this new service parameter;
This parameter specifies the local route group to be used for a   redirected call. Valid values follow: Local route group of calling   party: When this value is selected, the local route group associated   with the Device Pool of the Calling Party is used for routing the call.   Local route group of original called party: When this value is  selected,  the local route group associated with the Device Pool of the  Original  Called Party is used for routing the call. Local route group  of last  redirecting party: When this value is selected, the local route  group  associated with the Device Pool of the Last Redirecting Party is  used  for routing the call.
   This is a required field.
   Default:                  Local route group of calling party
Cheers!
Rob
"A smile relieves a heart that grieves"
- Stones
VIP Super Bronze
Are you using local route groups? What versionof CUCM is this?
Hi Aokanlawon:
Yes I use local route groups. The version of CUCM is 8.6
VIP Super Bronze
To resolve this..
Thank you very much for the info. I am glad it is a documented issue, not the one that I created myself lol. Two more things:
1. Would you explain a bit more on your first suggestion ie. use full dialing pattern.
2.  When I call the forwarding extension from location 1, it seems to me like the call is routed through the local gateway as your rightfully pointed. However, when I call the forwarded number (final destination of the call, pstn number), I am not prompted to prefix 1. I think my TEHO kicks in there. So, in the scenario that I have described above, TEHO does not come into play?
Thank  you,
I am still waiting if some body can help me understand :
- Per Aokanlawon, what I have been experiencing above is a documented issue and there are a few workarounds to that. He gave 3 options. I use TEHO between location 1 and 2 for intersite PSTN calls. When someobdy from locatioin 1 calls a PSTN number local to location 2, the call is handed off to the gateway local to location 2 as it should in TEHO. However, my question here is, why, when someobdy from location 1 calls soembody in location 2 in his/her extension who has setup call forwarding to his/her home phone (local number to location 2) the call does not go through the local gateway in location 2. Can I assume TEHO does not kick in the situation I described above?
Thank you,
VIP Super Bronze
Hi Badri,
Cheers!
Rob
- Stones
Thank you Aokanlawon and Rob for great info. You guys always deserve more than +5.
Hi guys,
This new Service Parameter affects every forwarded calls, right? No matter if it is All, Busy, No Answer or Unregistered.
What if I want to change this behavior for CFA only? Do I have any option?
Because for CFUR, it is very useful when CUCM routes the call to the Calling Side gateway, so I can keep things working when the other site is in SRST.
Bruno
418
