04-28-2014 11:29 PM - edited 03-16-2019 10:36 PM
Is it possible if someone calling from outside to Cisco's call manager one extension/DID number and from that number possible to dial outside again? going to use it for international dialling ...
Solved! Go to Solution.
04-29-2014 03:10 AM
Yes it is called Mobile voice access you can have a pilot number login with your ext that you want to make the intl call with or internal call or national call.
Please read the following link.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/6_0_1/ccmfeat/cmfsgd601/fsmobmgr.html
04-29-2014 03:10 AM
06-01-2014 10:12 PM
Is it allowing to unknown call from outside to CUCM? Mobility is forwarding call to mobile phone right?
06-02-2014 07:06 AM
The link that has already been provided explains Mobility and answers your questions, have you gone thru it???
06-02-2014 01:43 PM
You're thinking of Mobile Connect/Single Number Reach. Mobile Voice Access as described in the posted documents allows you to call a pilot number from a PSTN device and enter your pin and then allows you to enter a number to call on your behalf and connects the 2 legs together.
04-30-2014 02:29 AM
Apart from MVA feature, you can use Unity (voice mail appl) to dial outside from the system as well but that can leads to toll-fraud.
Suresh
