Call forwarding solution
Is it possible if someone calling from outside to Cisco's call manager one extension/DID number and from that number possible to dial outside again? going to use it for international dialling ...
1 ACCEPTED SOLUTION
Yes it is called Mobile voice
Yes it is called Mobile voice access you can have a pilot number login with your ext that you want to make the intl call with or internal call or national call.
Please read the following link.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/6_0_1/ccmfeat/cmfsgd601/fsmobmgr.html
Voice CCIE #37771
Voice CCIE #37771
Hi,  Is it allowing to
  Is it allowing to unknown call from outside to CUCM? Mobility is forwarding call to mobile phone right?
The link that has already
The link that has already been provided explains Mobility and answers your questions, have you gone thru it???
java
if this helps, please rate
www.cisco.com/go/pdi
You're thinking of Mobile
You're thinking of Mobile Connect/Single Number Reach.  Mobile Voice Access as described in the posted documents allows you to call a pilot number from a PSTN device and enter your pin and then allows you to enter a number to call on your behalf and connects the 2 legs together.
VIP Gold
Apart from MVA feature, you
Apart from MVA feature, you can use Unity (voice mail appl) to dial outside from the system as well but that can leads to toll-fraud.
Suresh
191
