Call forwarding status in CUCM 8.5.1
Is there a report to discover what DNs have forwards (CFwdALL) set?
We are using CUCM 8.5.1
Matt
No you would either need to export the info with BAT (this will include ALL phones so you then need to sort them out) or if you really want the ones with CFA run some qrys via CLI for this.
There are already some queries for that on CSC so if you take some time to search you'll find them.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Matt
Hall of Fame Super Red
Hi Matt,
Just to add a bit to the nice info from our friend Java (+5 Java )
Check out the great work from Dan and Kim in this thread;
https://supportforums.cisco.com/message/1182357#1182357
Cheers!
Rob
246
