Call forwarding to multiple destinations?
oldsbravada
Issue: I need to have a internal number forwarded to multiple extensions.I am running CUCM 6.1.2.1000-13
Aaron Harrison
A phone can have one 'Call Forward All' destination.
That destination could be a hunt group pilot if you wish.
What exactly do you want to achieve in detail?
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
William Bell
You may want to have the phone forward to a Hunt Pilot. Then assign the target phones (for the forward) to a Line Group. Configure the Line Group to use "Broadcast" hunting algorithm (which means it will ring all phones). So, the procedure:
1. Identify target phones
2. Assign phones to Line Group (e.g. myLineGroup) and configure for Broadcast
3. Create a new Hunt List (e.g. myHuntList) and assign myLineGroup to the HuntList
4. Create a hunt pilot (the number you forward to from the IP phone) and assign the huntlist myHuntList
Test it out.
HTH.
Bill
Please remember to rate helpful posts.
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Thanks Aaron & William! I will try the Hunt Pilot
scenario - update to follow.
