Community Member
CALL FORWARDING TO PSTN FAILS
I am using an E1 isdn pri line for my ccme but call forwarding to a PSTN number fails if the call to be forwarded originates from the PSTN.
When i activate call-forward all, callers from PSTN gets a fast busy tone instead of being redirected to the PSTN number the call has been forwarded to.
When i call the same extension from another internal extension, the call forward is successful.
help please
Hall of Fame Super Gold
Re: CALL FORWARDING TO PSTN FAILS
Take "debug isdn q931" with "term mon" when attempting a CFA from pstn.
Community Member
I'd want to know if you define the call-forward pattern in telephony-service mode. If you've not done yet, please do it now.
conf t
telephony-service
call-forward pattern .T
Ronalddiane, if the OP had not configured a correct transfer-pattern already, also forwarding for internal calls would not work, instead it does.
Community Member
I have a similar problem , where the call forward works from the internal number and it dones not work from the external number, the debug ISDN q931 shows " Incomplete number "
Good CALL
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Exclusive, B1
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0080, '205788388'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '0611818625'
BAD CALL:
Standard = CCITT
Channel ID i = 0x89
Exclusive, B1
Progress Ind i = 0x8283 - Origination address is non-ISDN
Calling Party Number i = 0x00A3, '205788388'
Called Party Number i = 0xA1, '0611818625'
Plan:ISDN, Type:National
Sending Complete
004493: Feb 26 06:01:24.020: ISDN BR0/0/1 Q931: RX <- STATUS pd = 8 callref = 0x92
Cause i = 0x82E41E - Invalid information element contents
Call State i = 0x01
004494: Feb 26 06:01:24.096: ISDN BR0/0/1 Q931: RX <- CALL_PROC pd = 8 callref = 0x92
Channel ID i = 0x89
Exclusive, B1
004495: Feb 26 06:01:24.816: ISDN BR0/0/1 Q931: RX <- DISCONNECT pd = 8 callref = 0x92
Cause i = 0x879C - Invalid number format (incomplete number)
Any help will be greatful !
ARIF
Community Member
Someone somewhere must have solved this problem, help out, its running out of hand please.
Symon: you have not sent the "debug isdn q931" that had been asket. You cannot be helped if you do not send it.
Arif: try
interface bri x/y/z/
isdn map address . plan unknown type unknown
Community Member
Thanks for the reply and the suggession, it did not help , i have attached the config of cme and the log when i enable CFD and when i call the phone directly. ( debug isdn q931 & debug voice ccapi inout)
Request you to verify and let me know if you find some issue in the configuration.
Do you think this would be problem with the telecom provider ?
Thanks again & await for you reply.
ARIF
Command is:
not
isdn map address plan plan unknown type unknown
Community Member
Hi all the good people, see attached the output for debug isdn q931 from my ccme router when i make a call to a number with cfa activated.
Would appreciate any suggestion leading to the correct solution of the problems.
Thanks in advance.
Which exact IOS are you using?
Please take another trace enabling also "debug voice ccapi default"
Community Member
here is my debug voice ccapi default output.
Community Member
i will try out this tht helped out my friend n see the result.
Community Member
Hi bevilacqua
The CFD challenge has been fixed now after applying the command on the BRI interface
Thanks for your prompt support and right solution.
ARIF
Community Member
I have one more clarifcation with regards to the CFD.
How can i enable CFD to the Secondary number alone ( DID NUmber ), indeed i have tried using the command on ephone-dn "no foward local calls" , if i do this , then extenal call forward is working fine, but if call the phone on the internal number from internal phone , it gives fast busy tone.
Please help, and let me know how can setup the CFD only on the external number.
ARIF
644
