Call forwarding using FXO Ports
Dear All,
I have a telephony system already in place with 6 FXO active ports configured on a 2821 Router.
The thing is that I am not able to make an ip phone forward calls to a mobile No.
I can make calls to the same mobile number when dialed from the phone but the call routing seems not to function correctly when call-forward all is configured on the ephone-dn.
I would like to focus only on voice-port 0/0/0 and 0/0/1
Please have a look at my configurations:
voice-port 0/0/0
supervisory disconnect anytone
output attenuation -3
echo-cancel coverage 32
compand-type a-law
cptone GB
timeouts call-disconnect 5
timeouts wait-release 5
connection plar opx 300
impedance complex2
description ***Konoba 345400***
caller-id enable
voice-port 0/0/1
compand-type a-law
cptone GB
impedance complex2
description ***Konoba 345713***
caller-id enable
spfarm profile 13 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 2
associate application SCCP
dspfarm profile 14 mtp
codec g711ulaw
maximum sessions software 250
dial-peer voice 2 pots
corlist outgoing call-local
tone ringback alert-no-PI
destination-pattern 0.......
progress_ind setup enable 3
progress_ind progress enable 8
progress_ind disconnect enable 8
forward-digits 7
port 0/0/0
dial-peer voice 3 pots
preference 1
forward-digits 7
port 0/0/1
ephone-dn  26  octo-line
number 300
label KO-Reception
description 300
name KO-Reception
call-forward all 02523379
corlist incoming user
PBX#show voice port summary
                                           IN       OUT
PORT            CH   SIG-TYPE   ADMIN OPER STATUS   STATUS   EC
0/0/0           --  fxo-ls      up    dorm idle     on-hook  y
0/0/1           --  fxo-ls      up    dorm idle     on-hook  y
0/0/2           --  fxo-ls      up    dorm idle     on-hook  y
0/0/3           --  fxo-ls      up    dorm idle     on-hook  y
0/1/0           --  fxo-ls      up    dorm idle     on-hook  y
0/1/1           --  fxo-ls      up    dorm idle     on-hook  y
0/1/2           --  fxo-ls      up    dorm idle     on-hook  y
0/1/3           --  fxo-ls      up    dorm idle     on-hook  y
Any help would be very much appreciated.
Thanks and Best Regards.
Pascal Douce
Hall of Fame Super Silver
Do you have call forward pattern defined under telephony-service?
Can you post your telephony-service config?
Chris
Re: Call forwarding using FXO Ports
Dear Chris,
Please find below the output of the telephony-service config.
telephony-service
sdspfarm units 5
sdspfarm transcode sessions 50
sdspfarm tag 1 mtp-dsp
sdspfarm tag 2 transcode
video
  maximum bit-rate 64
load 7914 S00105000200
load 7906 SCCP11.8-2-2SR1S
load 7911 SCCP11.8-3-3S
load 7921 CP7921G-1.0.1
load 7936 cmterm_7936.3-3-12-0
load 7960-7940 P00308000400
load 7941 SCCP41.8-2-2SR1S
load 7942 SCCP42.8-3-2S
load 7945 SCCP45.8-3-3S
load 7961 SCCP41.8-2-2SR1S
load 7962 SCCP42.8-3-3S
load 7975 SCCP75.8-3-3S
max-ephones 48
max-dn 48
ip source-address 10.10.10.1 port 2000
service phone videoCapability 1
timeouts interdigit 3
system message Welcome!
url information http://64.73.32.133/menu.xml
url services http://192.168.10.101/services.xml
url authentication http://10.10.10.50/voiceview/authentication/authenticate.do
cnf-file location flash:
time-zone 35
time-format 24
date-format dd-mm-yy
live-record 8900
voicemail 2000
max-conferences 8 gain -6
moh music-on-hold.au
multicast moh 239.10.16.4 port 2123
web admin system name eme secret 5 $1$ZrO8$B37M6emmBK5krvq220omt0
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
secondary-dialtone 0
login timeout 5 clear 18:00
after-hours block pattern 1 0
after-hours block pattern 2 9
after-hours block pattern 3 700230
after-hours day Sun 00:00 23:59
after-hours day Mon 00:00 23:59
after-hours day Tue 00:00 23:59
after-hours day Wed 00:00 23:59
after-hours day Thu 00:00 23:59
after-hours day Fri 00:00 23:59
after-hours day Sat 00:00 23:59
directory entry 1 100 name Reception
create cnf-files version-stamp 7960 Jun 26 2012 05:09:19
Thx.
Can you add somthing like this:
transfer-pattern 4...
transfer-pattern .T
call-forward pattern 4...
call-forward pattern .T
Chris
I will try these commands ASAP and revert back to you.
Thank you Chris.
Pascal
Chris,
I have added the command 'call-forward pattern .T' to telephony-service configuration but the call is still not routing properly.
Please find below the output from debug voip dial-peer all.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2012.06.30 09:55:55 =~=~=~=~=~=~=~=~=~=~=~=
term mon
PBX#
PBX#
Scenario. Phone Line 4679001 is calling 2345400( FXO voice port 0/0/0) on PBX. Incoming call is routed to phone (ephone-dn 26 dual-line) which should forward the call to mobile No 02523379.
Jun 30 05:55:23.909: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=4679001, Called Number=, Voice-Interface=0x48FE200C,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Result=Success(0) after DP_MATCH_PORT; Incoming Dial-peer=100
Jun 30 05:55:23.913: //-1/04A396748148/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=300, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=300
   Result=Success(0) after DP_MATCH_DEST
Jun 30 05:55:23.913: //-1/04A396748148/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=20004
Jun 30 05:55:23.913: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=300, Called Number=300, Peer Info Type=DIALPEER_INFO_SPEECH
Jun 30 05:55:23.913: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   Calling Number=, Called Number=02523379, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=02523379
   Result=SUCCESS(0)
     1: Dial-peer Tag=3
     2: Dial-peer Tag=2
     3: Dial-peer Tag=4
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
     6: Dial-peer Tag=7
   Calling Number=02523379, Called Number=02523379, Peer Info Type=DIALPEER_INFO_SPEECH
Jun 30 05:55:23.917: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Jun 30 05:55:23.917: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=3
     2: Dial-peer Tag=2
     3: Dial-peer Tag=4
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
     6: Dial-peer Tag=7
Jun 30 05:55:23.917: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=02523379, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Result=NO_MATCH(-1) After All Match Rules Attempt
   Result=SUCCESS(0)
Jun 30 05:55:23.917: //-1/04A396748148/DPM/dpMatchPeersCore:
Jun 30 05:55:23.917: //-1/04A396748148/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   Result=SUCCESS(0)
     1: Dial-peer Tag=3
     2: Dial-peer Tag=2
     3: Dial-peer Tag=4
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
     6: Dial-peer Tag=7
   Calling Number=, Called Number=4679001, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=4679001
   No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
Jun 30 05:55:23.921: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=NO_MATCH(-1)
Jun 30 05:55:23.921: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Result=SUCCESS(0)
     1: Dial-peer Tag=3
     2: Dial-peer Tag=2
     3: Dial-peer Tag=4
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
     6: Dial-peer Tag=7
Jun 30 05:55:23.925: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Jun 30 05:55:23.925: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
Jun 30 05:55:35.293: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=, Called Number=, Voice-Interface=0x48FE200C,
Jun 30 05:55:35.297: //-1/0B6CAE74814F/DPM/dpMatchPeersCore:
Jun 30 05:55:35.297: //-1/0B6CAE74814F/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Jun 30 05:55:35.297: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Jun 30 05:55:35.301: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Jun 30 05:55:35.301: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Jun 30 05:55:35.301: //-1/0B6CAE74814F/DPM/dpMatchPeersCore:
Jun 30 05:55:35.301: //-1/0B6CAE74814F/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=3
     2: Dial-peer Tag=2
     3: Dial-peer Tag=4
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
     6: Dial-peer Tag=7
   Result=SUCCESS(0)
     1: Dial-peer Tag=3
     2: Dial-peer Tag=2
     3: Dial-peer Tag=4
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
     6: Dial-peer Tag=7
Jun 30 05:55:35.301: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=SUCCESS(0)
   Result=SUCCESS(0)
   Result=SUCCESS(0)
     1: Dial-peer Tag=3
     2: Dial-peer Tag=2
     3: Dial-peer Tag=4
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
     6: Dial-peer Tag=7
Jun 30 05:55:35.305: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Jun 30 05:55:35.305: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=3
     2: Dial-peer Tag=2
     3: Dial-peer Tag=4
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
     6: Dial-peer Tag=7
Jun 30 05:55:35.309: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Jun 30 05:55:35.309: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
Jun 30 05:55:47.297: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Jun 30 05:55:47.305: //-1/1294FBEB8156/DPM/dpMatchPeersCore:
Jun 30 05:55:47.305: //-1/1294FBEB8156/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Jun 30 05:55:47.305: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Jun 30 05:55:47.305: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   Result=SUCCESS(0)
     1: Dial-peer Tag=3
     2: Dial-peer Tag=2
     3: Dial-peer Tag=4
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
     6: Dial-peer Tag=7
   Result=SUCCESS(0)
     1: Dial-peer Tag=3
     2: Dial-peer Tag=2
     3: Dial-peer Tag=4
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
     6: Dial-peer Tag=7
Jun 30 05:55:47.305: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=SUCCESS(0)
Jun 30 05:55:47.309: //-1/1294FBEB8156/DPM/dpMatchPeersCore:
Jun 30 05:55:47.309: //-1/1294FBEB8156/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Jun 30 05:55:47.309: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Jun 30 05:55:47.309: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=3
     2: Dial-peer Tag=2
     3: Dial-peer Tag=4
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
     6: Dial-peer Tag=7
   Result=SUCCESS(0)
     1: Dial-peer Tag=3
     2: Dial-peer Tag=2
     3: Dial-peer Tag=4
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
     6: Dial-peer Tag=7
Jun 30 05:55:47.313: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Jun 30 05:55:47.313: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
Jun 30 05:56:00.041: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=4679001, Called Number=, Voice-Interface=0x48FE400C,
   Result=Success(0) after DP_MATCH_PORT; Incoming Dial-peer=101
PBX#
PBX#
PBX#
PBX#
PBX#show dial-peer voice summary
dial-peer hunt 0
             AD                                    PRE PASS                OUT
TAG    TYPE  MIN  OPER PREFIX    DEST-PATTERN      FER THRU SESS-TARGET    STAT PORT
1      voip  up   up             2000               0  syst ipv4:10.10.10.50
3      pots  up   up             02523379           1                      up   trunkgroup 1
4      pots  up   up             0.......           2                      up   0/0/2
5      pots  up   up             0.......           3                      up   0/0/3
6      pots  up   up             0.......           4                      up   0/1/0
7      pots  up   up             0.......           5                      up   0/1/1
2      pots  up   up             0.......           0                      up   trunkgroup 1
100    pots  up   up                                0                      down 0/0/0
101    pots  up   up                                0                      down 0/0/1
102    pots  up   up                                0                      down 0/0/2
           AD                                    PRE PASS                OUT
103    pots  up   up                                0                      down 0/1/0
104    pots  up   up                                0                      down 0/1/1
20001  pots  up   up             199$               0                           50/0/5
20002  pots  up   up             8900$              0                           50/0/7
20003  pots  up   up             303$               0                           50/0/25
20004  pots  up   up             300$               0                           50/0/26
20005  pots  up   up             301$               0                           50/0/27
20006  pots  up   up             304$               0                           50/0/30
20007  pots  up   up             360$               0                           50/0/36
20008  pots  up   up             800...             0                           50/0/40
20009  pots  up   up             801...             0                           50/0/41
           AD                                    PRE PASS                OUT
20013  pots  up   up             A334A0100          0                           50/0/30
20014  pots  up   up             334                0                           50/0/0
PBX#
Thank you.
Hall of Fame Super Gold
To begin with, do not use multipel DP's. Place the FXO ports under a single DP and reference it under a a singel DP.
Also you don't need any progress_ind command.
Hi All,
I've done some more research and found that the After Hours configuration is preventing the call forward to work as it should.
The scenarios below explain the issue in more details :
Call forward scenario works :
Internal Extension -- calls-- Extension on CME(with CFA)
Call forward scenario fails :
PSTN No -- calls-- Extension on CME (with CFA)
When the PSTN call come in , the call hit the dial-peer for the specific DN which has CFA configured. Since no after hours exempt command exists on ephone-dn, the called No is blocked since the prefix matches the block pattern in the After-Hours config.
A solution would be to put a prefix which does not match the block pattern in the CFA No + create a Dial-peer specially for the called No.
When the Internal No calls Extension No with CFA configured, it hits the phone which has after hours exempt configured..which allow the call to get through After Hours config.
Pascal Douce
2325
