Call forwarding
Hai all,
There is an issue with the ip phone of my customer. she says, when made calls to forward to the mobile. The call forwards function times out after 8 hours instead of being permanent. We using ccm5 version.
Please help
Re: Call forwarding
Does the user log onto the phone with extension mobility?
Re: Call forwarding
NO they wont.
Re: Call forwarding
Have you witnessed this by yourself?
Or someone told you he thinks this is the behavior?
I ask because many times what an end customer says and the actual behavior do not match and the issue is something else
full CUCM version??
The only thing i could think of right now would be db replication issues. Does this happen to phones registered to SUB and PUB??
java
if this helps, please rate
java
www.cisco.com/go/pdi
Re: Call forwarding
The issue is seen in phone reg to sub.
126
