Call Forwarding
If an internal user dials a users extension the call forwards to the users cell phone...good.
If someone calls the user using the main company number with his extension on the end (xxx-xxx-5914) the call forwards to his cell phone....good.
If someone calls the main office number then enters in his extension when prompted the call does not forward and goes to voice mail...bad.
Any ideas why?
This is CCM 3.3
Re: Call Forwarding
guess you don't have the same CFNA and CFB for internal and for external.
calls routed from unity are considered internal and that is working as designed
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Re: Call Forwarding
Sorry but I don't know what CFNA or CFB mean.
Re: Call Forwarding
Call Forward No Answer
Call Forward Busy
javalenc
java
Hall of Fame Super Red
Re: Call Forwarding
Hi Randy,
Just to add a note to the good info from Jaime, I don't think the Internal/External Forward settings existed in CCM 3.3. Can you take a look at the Transfer settings in Unity and make sure they are set to "Ring Phone" not "Directly to VM"
Just a thought,
Rob
Re: Call Forwarding
It's set to ring his extension.
And no, I don't see any internal/external forwarding settings.
Re: Call Forwarding
I wanted to bump this up so some others have a chance to see it.
I still haven't been able to figure this out.
Re: Call Forwarding
Hate to bump this up again...but we're still unable to figure out what is causing this problem.
Re: Call Forwarding
I'm going to assume you have unity for your Autoattendant. Under the Call directory how is Unity set to transfer the call? Blind or supervised?
It sounds like Unity is not releasing the call...
Just a guess tho...
Re: Call Forwarding
What is the Unity version that you are using?
If you open the port status monitor, what do you see on the port that is handling the call?
Re: Call Forwarding
When the main office number is called, what is handling the call from there? Is it Unity?
It sounds like whatever it is does not send the call to the phone for it to be diverted on to the cell phone.
All the above instances that you have outlined appear to show that call manager is doing it's job ok.. but the last instance seems to indicate that the call is staying within the Voice mail application and not being sent on.
Do any other users have this problem? Are they set up the same way?
Re: Call Forwarding
conf t
ephone-dn X
call-forward noan xxx-xxx-5914 timeout 16
please rate this post if helpful
Re: Call Forwarding
disregard the last post I thought it was an callmanger express.
204
