Community Member
Call Forwrding no answer and Voice mail
I habve cisco CM 7.0 running in my environment. My question is If i do call forwarding no answer setup for a user to another , how can i make sure if the call is not answered by another user - comes back to voicemail of first user. For example:
User1: extension 1122
User2: extension 1133
On 1122 I setup "Foward No Answer Internal/External" to 1133. How do i achieve if the original call that was for 1122 is not answered by 1133 goes back to voice mail of 1122.
I know this is very much possible on Nortel/Avaya but I am new to Cisco. Thanks for your help in adavace.
Adil
1 REPLY
1133 (or another phone down the line) has to ultimately divert the call to Voicemail. You don't say what voicemail system you're using, but if the voicemail system is being sensible (most are, but some aren't) it will see that the call was originally for 1122 (even though a different extension diverted the call to voicemail) and send the call to 1122's voicemail box.
If you're after CUCM ignoring any divert setting on 1133 and sending it voicemail on no answer on 1133, then I don't think you can do this.
GTG
Please rate all helpful posts.
112
